December 21, 2024, 07:22:48 PM *
Pages: 1 [2] 3   Go Down
Author Topic: Don't trust the rev counter...  (Read 12613 times)
« Reply #15 on: April 16, 2012, 11:41:25 AM »
Well, as long as it's got rods, it's got rod bolts.  Tongue
Omnipotent Potentate
Personal Pretext
« Reply #16 on: April 17, 2012, 07:31:42 AM »
I was under the impression everything has a rev limiter.
Well, yes - but those are also call critical points of mechanical stress failure. All the EFI ducs to have an ignition cut-out limiter.
But older carbie bikes with no brain could be pushed past the recommended RMP ceiling. OF course that's at your own peril as too much of that and bits stop being connected like the should.
Also, many times peak power is achieved before the limiter  so anything past peak power and you're losing out and and the next gear will be better.
Look at some dyno graphs and you'll see it go up-up-up and right before the lines stop it goes over the hump and heads down again.
bdub
« Reply #17 on: April 18, 2012, 11:31:30 AM »
but since the OP was talking 796, I assumed fuel injection. I realize everything will eventually spin out of control. It's happening now with me (slowly)
2005 900ie
now with mivv s'
Y2K  M900 ie  totaled  10/09/08
duc996
« Reply #18 on: April 24, 2012, 01:59:11 AM »
I would just listen and feel for the bike, and not look at the tach.
       "Monster S4r"
       "KTM SMC 690"
Privateer
« Reply #19 on: April 24, 2012, 04:54:49 PM »
i'm curious, have you previously ridden mostly i4's?
bdub
« Reply #20 on: April 25, 2012, 04:09:58 AM »
If you are asking me, then no. I've only had mine 900. Not counting the 125 I had 35 years ago. I really don't pay any attention to my tach unless I'm trying to figure out speed at a particular rpm.
I just shift when it sounds right.
2005 900ie
now with mivv s'
monsterjoe
« Reply #21 on: June 19, 2012, 10:21:41 AM »
ive hit about 8000 rpm, can i hit it till 11000? rpm? i ride a 620 dark 2005
Personal Pretext
« Reply #22 on: June 20, 2012, 07:08:13 AM »
Nope - you've missed the fundamentals of the discussion perhaps.
1) Your bike has an electronic limiter that kicks in some place just beyond 8000.
2) More Revs /= more better, especially going that high.
   - After a point the engine will produce less power. Generally the Rev limit and engine tune are set to work together. The limit being set at a point just beyond the point where power starts to drop off.
   - Too high an RPM in and engine not designed for it is a good way to destroy it. I'd wager that if you managed to run a 620 engine up to 11,000 RPMs via messing with the electronics, it would be a lesson on critical mechanical failure.
herm
« Reply #23 on: June 20, 2012, 06:58:36 PM »
everyone should seek out the rev limiter (in a safe and controlled situation.) this will achieve two things.
1- you will know what it feels like, and not panic when/if you hit it by mistake
2- you will know where it is, which is pretty important because you don't want to bang up against it when you still need to be accelerating
Privateer
« Reply #24 on: June 23, 2012, 02:51:16 PM »
no, i was addressing the OP.
My unscientific research has shown me I4 riders have trouble riding twins because they want to wring the thing's neck out.  No amount of me trying to explain it helped, they only learned that docs are 'junk' because of an 8k rev limiter.
The Bacon Junkie
I have a Bacon Wrapped
Save the brass...
« Reply #25 on: June 30, 2012, 06:57:55 PM »
+1
I hit the limiter on my 999 in first gear by accident...
I was pulling out onto a two lane highway, across traffic.  The speed limit there is 55, but people routinely do 70ish...  Luckily for me, the Triple-9 has a TALL first gear!  Wink
It was almost as if I head a BANG in my head when it cut out...  But I think that was just my chest, then my chin, hitting the tank!  I didn't panic, but it certainly got my attention!!!  Shocked
Find your limiter when you're expecting it... not in a real world situation...  waytogo
 bacon
Save the Brass...
bdub
« Reply #26 on: July 04, 2012, 09:19:38 AM »
Is it hard on stuff if you hit the limiter to often ? I dont't hit mine often, usually shift around 6 - 7800 ish.
2005 900ie
now with mivv s'
Personal Pretext
« Reply #27 on: July 05, 2012, 12:03:32 PM »
Nah. that's the purpose of it. As long as you're not riding the limiter for extended periods, hitting it shouldn't make no nevermind
Triple J
« Reply #28 on: July 05, 2012, 01:57:02 PM »
Depends on who you ask, and how often you hit it I think. It's a fairly violent affair in Ducs compared to I-4s.
My 749 racebike has a broken crankshaft, and it previously had a spun crank bearing (crank itself was OK after that...although it may have been damaged internally and we couldn't tell). It has been suggested that hitting the rev limiter too often may have contributed to the problem. When I get it back I will be putting a big piece of red tape on the tach. at 10,500 rpm to help keep me from doing it again. It may not have caused the failure, but it surely didn't help.
herm
« Reply #29 on: July 06, 2012, 12:00:36 PM »
the other important take away here is that there is NO REASON to be regularly bouncing of the rev limiter on a duc! but the time you hit it, you are way past the top of the power curve... = less power.
once you learn where it is, shift accordingly and stay away from it.
Pages: 1 [2] 3   Go Up
