Well, it finally happened...
Started by hypurone, June 24, 2008, 04:40:37 PM
truckinduc
Spoooge.
My next new bike* will have a set of those...
*Currently slated for 2030, the year the kids graduate...
Big Troubled Bear
hypurone
Quote from: Drunken Monkey on July 14, 2008, 09:59:29 PM
Spoooge.
Jeebus! and here I thought waiting almost eight years was a marathon.... I'm pullin' for ya man!  [moto]
Carman
Did you ever run into clearance problems with the 6" width and 520 chain?  I'm supposed to be getting my BST's soon.
Carman
'07 S4RS
hypurone
Quote from: Carman on August 13, 2008, 07:25:15 AM
There is more clearance to the 190 tire (a 180 shouldn't be run on a 6.0 rim even tho it can be listed on some sites) with the 520 than the stock 525. About a 1/16 - 1/8 inch. The problem you will run into is the clearance between the wheel and the swingarm (at the brace transition to the rear hub). I had only 1/8 inch!! And if the chain needed to be adjusted (it did after a few rides) I had no room to do so! So I needed to replace the sprockets in a combination that would move the wheel forward and allow room for future adjustments. I decided to do a 520 quick change conversion in the process.
Carman
Quote from: hypurone on August 13, 2008, 07:48:24 AM
Maybe I'm not understanding, you said clearance between the wheel and swingarm (where the front part of the wheel meets the swingarm on the left side) after streching a new chain wouldn't you be moving it rearward and not forward?  I've never done this before, also I've got the same model (S4Rs testretta) where did you source your 520 quick change conversion from?  Appreciate the time and help.
Carman
'07 S4RS
hypurone
#37
Quote from: Carman on August 13, 2008, 09:19:41 AM
I went from a 14/43 & 104 link chain to a 15/45 & 104 link chain. This shortens the distance and requires the chain eccentric to be adjusted forward to make enough slack to get the chain on the larger sprockets. The clearance issue was at the left side of the wheel where it passes close to the swingarm brace as it transitions downward to the hub eccentric. Capish?
I bought my stuff from Sprocket Center.
EDIT: I originally bought a 46 in the "kit" from Sprocket Center but that wouldn't fly on a 104 link chain, had to source the 45 from Munroe...
Carman
Carman
'07 S4RS
hypurone
Quote from: Carman on August 13, 2008, 11:36:11 AM
Capish, thanks!
No problem, welcome anytime. lemme know if you have any more ?'s...  ;D
Rob Hilding
What color are you going to paint 'em?
JK
Congrats - look great on the bike [thumbsup]
hypurone
Quote from: bozcorob on August 13, 2008, 01:35:40 PM
JK
Paint CF, Sacrilege! I know you are JK, thanks for the props...
25KV
Quote from: hypurone on August 13, 2008, 01:59:09 PM
Wheels look KILLER, I am totally jealous!!!!! [thumbsup]
lazarus7
sexehhhhh....!!!!
very nice, congrats,
and thanks for the first pics of the new 7 spokers mounted.....
definitely on my list....!!!
"...the greatest artists indulge in a 'culpable rivalry' with God."     Stanislas Fumet
hypurone
Quote from: 25KV on August 13, 2008, 06:12:15 PM
Quote from: lazarus7 on August 13, 2008, 06:30:29 PM
sexehhhhh....!!!!
Yeah it's actually pissing my wife off with how much time I spend in the garage :o ing at them and cleaning them.  [laugh]  [laugh]  [laugh]  [laugh]
