February 10, 2025, 03:25:32 PM
ST2 added to the stable
Topic: ST2 added to the stable (Read 11474 times)
Re: ST2 added to the stable
Reply #30 on:
May 14, 2012, 12:28:12 PM »
oh. anyone know how to adjust the kickstand down a bit. i'm having issues with the shifter and the kickstand, i want to push the shifter down more but won't be able to get my foot under the shifter due to the wierd bar on the kickstand.
and the brake and shifter are so far inboard. so wierd. i have to point my toes in so much to shift or brake.
and the brake is super flat, is there a way to adjust it down?
Desmo Demon
Reply #31 on:
May 14, 2012, 03:52:06 PM »
Quote from: Raux on May 14, 2012, 12:28:12 PM
There was a recall on the shift lever for early '98 ST2 bikes this very reason. I forget which shifter it was, but the factory simply swapped the shifter with one form another model. I don't remember if the ST2 originally had a Monster shifter or if it was what they wound up putting on the bike. I have a spare set of rearsets, and they came with the same shift lever that is on my 748.
Some people can't stand the "dog-leg" kickstand. Many people replace them with a straighter '99+ sidestand. I am not sure if it will fix your issue, though. I have thought about chaning mine on a few occasions, but can't seem to talk my self into spending the money.
IBA #32735
triangleforge
I'm just a guy. I'm no
2000 Cagiva Gran Canyon
Re: Re: ST2 added to the stable
Reply #32 on:
May 14, 2012, 04:11:12 PM »
In addition to the DD headlight (which I've had on my wish list for years), one other mod I can heartily recommend is a little digital voltage meter to mount on the dash.
Here's the one I use:
http://www.alliedelec.com/search/productdetail.aspx?SKU=70101345
And here's where it's mounted:
It's a splendid bike, and you're going to love it (edit: but you're going to develop an unhealthy obsession with what the electrical system is up to
Last Edit: May 14, 2012, 06:38:00 PM by triangleforge
triangleforge
Reply #33 on:
May 14, 2012, 06:41:55 PM »
And in case you need a more informed opinion than mine, here's a video posted by the NW Area Service Manager for Ducati North America, Quentin Wilson, who loves his:
Why I love my Ducati ST2
Reply #34 on:
May 14, 2012, 08:48:06 PM »
Quote from: Desmo Demon on May 14, 2012, 03:52:06 PM
hmm. maybe i'll check into the recall. and the 99 has a different shape for the stand? cool thanks.
thanks for the tip on the volt meter. is this really a concern? i notice today the previous owner had a heated suit plug mounted under the seat. .
zooom
Reply #35 on:
May 15, 2012, 05:39:31 AM »
Quote from: Raux on May 14, 2012, 08:48:06 PM
the voltage regulators on those were deemed by most to not be in the most convenient location for to be able to be cooled or disapate heat well enough...some would cut the airbox and move it to be mounted on top in the direct flow of intake air....the 3 yellow wire connector to the stator is also dodgey at best and should be regularly checked and repacked with some dielectric grease...
2010 KTM 990 SM-T
Reply #36 on:
May 15, 2012, 06:03:02 AM »
Quote from: zooom on May 15, 2012, 05:39:31 AM
My regulator is mounted in the nose intake?
triangleforge
Reply #37 on:
May 15, 2012, 08:43:54 AM »
If it's still in the stock location, it's under the chin fairing, a little to the right of center. Tucked out of the wind, it's got little or no access to air cooling, and the stock unit in the 1998 is basically a lump of epoxy with no cooling fins or other external way of dissipating heat - and it regulates current by turning the excess power into heat, so all of those things become an issue. It's a poor design, and one that was rectified somewhat (no pun intended) by a switch from
two
single phase to three phase power in the 1999 and later ST2. Unfortunately, that leaves us with 1998 ST2s as the electrical orphans in the Duc line.
Common fixes (most of which have played out on my bike with me or the previous owners) include periodically just replacing the damn thing with another Ducati unit (which I don't believe are still available for this bike) when it burns up; adding cooling holes to the fairing and slathering on lots of heat sink putty to the bottom before mounting it; and relocating the R/R to a plate below the bottom triple clamp (Desmo Times sells this one
http://desmotimes.com/product99.htm
; I fabricated my own out of a piece of aluminum plate, which wasn't as pretty but works fine). My ST2 is currently on its second stator and fourth regulator (two stock Ducati, one Shindengen/Honda unit and now one from Rick's Motorsport
http://www.ricksmotorsportelectrics.com/proddetail.php?prod=10-001&pmc=OThEdWM5NDRTVDI=
) and I don't particularly like how smoothly it "regulates" the current. I'm probing the various connections to make sure none of those are the culprit for my voltage wandering almost constantly between 13.6 and 14.2 when I'm at around 4K RPM before I get serious about swapping in yet another regulator, this time a MOSFET unit.
See what I said about obsessive?
Last Edit: May 16, 2012, 08:15:37 AM by triangleforge
triangleforge
Reply #38 on:
May 15, 2012, 08:55:04 AM »
Oh, and one thing I've heard (from Quentin, the fellow in the video above) but never really tried - the R/R is working its hardest when the bike needs the least amount of electrical power, so it actually takes the load off to run accessories like heated clothing, chargers, etc. That's kind of the opposite of the advice given by the guy at Desmo Times, so take it with a grain of salt.
Speaking of which, you'll definitely want to add this to your shopping list: the Desmo Times "Desmodue/Desmotre Maintenance and Modification Guide" -
http://desmotimes.com/maintenance1.htm
. It's the closest you'll come to a user-friendly shop manual for this bike and has lots of good insight on 2-valve & 3-valve Ducatis in general.
Desmo Demon
Reply #39 on:
May 15, 2012, 11:26:30 PM »
I'm on my third regulator and second staor in 54k miles. I believe this new replacement stator is bad, because I'm having some issues with it and can't figure it out. I have not had the time or motivation to change it out, again. A new Ducatgi OEM '97-'98 stator is $89, so it's not too bad of a deal except for the labor to change it (even doing it myself it's a PITA).
I have added a voltmeter on the left dash panel. It's just one of those 2-1/4" units that you can buy at any auto parts store for about $20. BTW, my OEM regulator lasted 11k miles, the OEM replacement in the same location lasted 4k miles, and the relocated aftermarket regulator has lasted almost another 30k miles. I have my regulator sitting on a plate over the modified airbox so it will always see air flowing over it.
Here is an article I wrote on the regulator relo I did starting on page 23 -
http://usdesmo.com/leanings/Leanings_2006_4_Winter.pdf
I also did a battery conversion to the smaller, gel-cell unit of the newer bikes. Here's the conversion here starting on page 7 -
http://usdesmo.com/leanings/Leanings_2007_3_Fall.pdf
Oh yeah - yes, the '99 and newer sidestands are straight and not that odd-ball 90-degree kink of a "dog-leg" (the hind leg of a dog shape).
Quote from: triangleforge on May 14, 2012, 06:41:55 PM
This is why I love mine...
Last Edit: May 15, 2012, 11:31:14 PM by Desmo Demon
IBA #32735
triangleforge
Reply #40 on:
May 16, 2012, 08:27:00 AM »
I've also relocated the battery - replacing the original first with an Odyssey gel cell (which required some minor modifications to the battery box and a new, wider hold-down:
and then when that died (thanks to one of the fried regulators), an itty-bitty Shorai that fits perfectly under the seat:
Reply #41 on:
May 26, 2012, 11:28:42 AM »
So went to the garage to do the first st mod. tpo kickstand bolt to get rid of suicide style.
getting tools out and wife leans on bike then walks away. yep kickstand swings up but luckily stands it on the way leaning on the mirror. no damage just a nic on the paint.
Bolt changed. Future disaster averted
Reply #42 on:
May 31, 2012, 11:09:10 PM »
Took a ride on the Monster today.
While the ST is nice. I think i've I forgot how refined I made the Monster.
The clutch (being wet) is smoother on engagement and (being APTC) smoother on decel. The throttle with the Eleactron cam is tight and quick. Add the lightweight flywheel and it's just a rocket through the revs. And it really engine brakes well. The ST if you roll off the throttle it just keeps rolling and you HAVE to stab the brakes to slow down.
Which for brakes, the monster is a BEAST. The ST stockers scare me sometimes, i even overshot a into town ess curve they have to slow traffice down (luckily the exit is straight). Not sure if it's the older rubber lines or the brake calipers. The Monster with the radial brakes and braided lines just GRAB the Braking rotors. The ST hold on for dear life it seems.
Ergos, Even the monster stock seat is more comfortable. And now using the lower stock on the monster, the reach is damn near the same as the ST. I just sit more upright on the ST.
The shifter is better positioned on the monster as well as rear brake, not sure if that's the S&P rearsets or the poor ST setup.
And I've smoothed out the bike so much with DP ECU and PC V that the bike can use any throttle position without sputtering. The ST, sputters at 0-10% throttle around town.
The ST does have the room and storage and wind protection. Yesterday was full on raining and I didnt have to stop to put on rain paints. just a middle dampness in on the jeans. The Monster I would have been soaked.
The two up riding is damn near impossible on the Monster as well with the clipons and rearsets compared to the ST.
The ST has that smoother cruising motor. 6k rpm in 6th gear is just soooooo smooth on the autobahn.
AND of course the wife loves riding the ST together.
Definitely two very different bikes.
Reply #43 on:
July 26, 2012, 10:49:41 PM »
well, the battery light is flickering at times on the ST. I'm prediagnosing it as the regulator.
I've read MOSFET ones are the best, where do you get one?
Reply #44 on:
August 29, 2012, 02:49:56 AM »
Well it was the regulator. Since I bought it used in Germany, the dealer had to replace it under warranty (1year for used vehicles in Germany
Just picked up a Pilot Road 2CT rear
Does anyone see a problem running a Road 2ct rear with a Power front?
