1) Should. The clutch is hydraulic , thus not a cable. But The masters on both bikes have similar exit position and attachment to the slave, so you should be good on that front. But length will be your final arbiter.
Thanks. I really meant "choke", not clutch. My plan for the clutch & brake lines is to just make my own braided lines by cutting them to length and fitting Earl's banjos. For the brakes I'll go to a 2-line setup.
The throttle cable isn't anything special. Just the normal barrel ended sort. Again, length will be your main issue.
Thanks.
2) Got me there.
Yeah, I can't find this spec anywhere. Short of actually getting a set of cables in-hand and measuring them, I don't think that info will be forthcoming.
