February 05, 2025, 05:45:28 PM *
Pages: 1 2 3 [4]   Go Down
Author Topic: thinking about a 900SS/SP  (Read 9497 times)
Rob Hilding
« Reply #45 on: June 16, 2012, 10:09:23 AM »
About 7,000, I am officially the second owner - the real second owner never transferred title.
Needs head studs replaced - two broken one on each cylinder - otherwise it is near perfect
Thanks for the heads-up on the screws
Here's a pic: For some reason I get two images posting the pic from Flicker -
][url=http://www.flickr.com/photos/26792974@N08/2510087490/]
« Last Edit: June 16, 2012, 10:31:56 AM by BozcoRob » Logged
« Reply #46 on: June 16, 2012, 02:52:33 PM »
use the IMG tag not URL
That is effing HOT
the issue with the wheels is the material in the rim is softer than the screws.  the screws can work loose just enough that the carrier is pushing against the hole and then the rim-side hole gets oval.
solution is to remove the screws one by one, add blue loctite and retorque.
The corbin seat upgrade is nice.  I have a DP seat pad which is literally thick foam and nothing else, but it weighs about 0.001 oz.
Those Marvics are just awesome
« Last Edit: June 16, 2012, 02:54:17 PM by ducatiz » Logged
« Reply #47 on: June 17, 2012, 01:47:21 AM »
hands down my fav Ducati SS
« Reply #48 on: June 17, 2012, 02:25:12 AM »
I had a red '92 model, but the wheels needed replacement which was a shame.
It was a beautiful bike, unfortunately I had to sell it. Fortunately I sold it to one of my mates and not a stranger, so I can still ride and work on it.
sofadriver
« Reply #49 on: June 17, 2012, 04:56:20 AM »
I'm planning to replace the heavy wheels on my new ride with these.
Should I go with gold or dish out the extra bucks for polished?
http://www.tobefast.com/carrozv6-wheelset-ducati-900ss-c-63564-p-1-pr-1735-f-64263.html
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
zooom
« Reply #50 on: June 21, 2012, 09:55:40 AM »
black or gold...not the polished...then you'll look like a homey G that chromed his shizzle fo sho yo!
2010 KTM 990 SM-T
Moto Motivo
If You Can't Buy It, Build It.
« Reply #51 on: June 22, 2012, 01:24:20 PM »
how did they handle the VIN numbers?
The replacement frame has the same VIN as the original cracked frame.  The new VIN is stamped at the factory.
I have two frames, one white (cracked) and one gold (new), with the same VIN # as proof.  The new frame was then traded for the cracked frame at your local dealer. In my case, the dealer that ordered the new frame went bang before the frames were switched.
Perfect Functional Two Wheel Art
      www.motomotivo.com
Moto Motivo
« Reply #52 on: June 22, 2012, 01:43:48 PM »
Tongue That tail section looks like it has a flat screen TV glued to it.
The bike was built as a tribute to this 24 hour Bol d'Or F1 racer. Note the number plate on seat:
This is the tribute bike (96 900SS)
      www.motomotivo.com
Ducatamount
« Reply #53 on: June 22, 2012, 02:52:33 PM »
A list of alternative Ducati parts,many of them for a 900SS.
http://www.docsa.com.au/Technical%20stuff/Technical%20Stuff%20Alternative%20Parts.htm
half fast
Pages: 1 2 3 [4]   Go Up
