February 23, 2025, 06:26:23 AM *
News: Please Help
Author Topic: M1100 PCV Map  (Read 1079 times)
scooterd145
« on: June 20, 2012, 08:35:11 AM »
Hi, I am looking for a good starting map for my 09 M1100s. I know I SHOULD get it Dynoed and or I SHOULD get my stock ECU remapped and an Autotune setup but the fact of the matter is I need to do about 500 miles and break in my news cams before running it on a Dyno and I already spent my parts allotment before the wedding ;-) I have reached out to Dusty @ Dynojet and the only M1100 map he has is stock with Mivv slip-ons
So if you are willing to share a map that you have please PM me (this map does not have to match my setup, I am willing to do some analysis based on what setup you have).
My setup
DP Cams
DP Full System ECU
DP Air Filter
MWR Powerup filter kit
Stepper motor and exhaust valve removed (equivalent to 696 midpipe)
Power Commander V
HMF Slip-ons
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #1 on: June 20, 2012, 09:27:08 PM »
Pretty sure I got a map you could use.  PM me with an email address.
scooterd145
« Reply #2 on: June 21, 2012, 06:46:44 AM »
PM Sent. Thanks UNG!
scooterd145
« Reply #3 on: June 22, 2012, 08:14:47 AM »
Thanks Ung, much appreciated! I will let you know the results. Just on first look at the map it is something more along what I would expect then some of the crazy stuff I found...
Scott
Amlethae
ahm-leth-eye
If life is a stage, you'd better let me direct.
« Reply #4 on: June 22, 2012, 09:23:13 AM »
Would a PCV autotune setup help you get the map dialed in right?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #5 on: June 23, 2012, 03:14:58 AM »
Well, yes.  Depending.
Entirely depends on your AFR tables.  Garbage input, garbage output.
The PCV map I sent the OP is not an Autotuned map, it was dyno developed by a Ducati specialist for a setup similar to his.
