April 30, 2024, 01:02:22 PM
14t and Gas Mileage
Topic: 14t and Gas Mileage (Read 3264 times)
Lord_Bragle
Re: 14t and Gas Mileage
Reply #15 on:
July 02, 2008, 01:41:11 PM »
I’m getting 65 miles to the gallon on average out of my S2R, quite incredible I know, but I am following my wife around on her 125 as she learns, I rarely go over 3000 rpm as I ride along now, I do have the 14T sprocket and I couldn’t say if it improves my mileage but it sure makes tootling around town behind the wife easier.
OT
Still Sweeping.....
Reply #16 on:
July 02, 2008, 05:42:44 PM »
Changing my sprocket (15 to 14) had the overall effect of lowering the bike's speed a little at any given RPM or, conversely, bumping the rpm up a little (3-4K) at the same indicated speed. But just a little -- it's not a major change.
So, now I can comfortably ride below 15 mph in 1st gear. BTW, this is the only reason I changed the sprocket....I can still hit 120 mph indicated on the turnpike.
Cucciolo
Reply #17 on:
July 02, 2008, 07:50:32 PM »
Quote from: OT on July 02, 2008, 05:42:44 PM
Me too! and it behaves so much better!
VeryMetal
Reply #18 on:
July 02, 2008, 09:01:10 PM »
Doesn't swapping sprocket sizes effect your speedo? I had an R6 and dropped a few teeth to improve low end pull away and just dropping a couple teeth was enough to throw my speedo way off. I know there's a bunch of little speedo healer products you can buy but I never got the chance to install one.
I usually try to cruise around between 4000 and 5000 rpms on my 02 750. Feels good, seems to be right in the middle of the powerband. Am I correct in assuming that if I fitted a 14t sprocket as opposed to a 15t it would cruise at the same speed at around 3500 as it did previously at 4000 rpms?
2002 Ducati Monster 750ie Dark
2005 Monster S2R Dark
vwboomer
Reply #19 on:
July 03, 2008, 06:01:06 AM »
Quote from: VeryMetal on July 02, 2008, 09:01:10 PM
No it doesn't.
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
OT
Still Sweeping.....
Reply #20 on:
July 04, 2008, 05:25:12 AM »
Speed on (only newer?) Monsters is measured at the rear wheel -- I believe it's a magnetic device that 'counts' the bolts on the rear sprocket as they pass by. If correct, it would probably take a major wheel change (i.e., bolt pattern/number) to affect the speedo.
Last Edit: July 04, 2008, 05:37:57 AM by OT
