Miscellaneous cool English bikes.
Started by brimo, July 20, 2012, 04:10:58 AM
Kopfjäger
Mmmm... Lavorton, that sounds good!
DucHead
Truckedup
 I just finished the build on this dual engine Triumph land speed racer...
Naked frame LSR..Riders dressed in animal hides clinging to oily vibrating machines propelled by fire
You're 7 weeks ahead of schedule, you should be ashamed of yourself.
Quote from: Speeddog on June 20, 2017, 02:47:17 PM
I don't see a vid of it running. :P
Truckedup
#263
  We run at 1-1/2 mile in Loring Maine....A crappy video I took of the bike on the Superflow chassis dyno about a month ago. The guy in the foreground is my rider, the other man owns the dyno shop...Made 10 runs from 2500-7500 rpm for reliability testing...
Kopfjäger
Truckedup
#267
  ......The bike has a Harley 5 speed and clutch ,the Harley electric starter is also used....I built it from a pile of parts...90's Suzuki wheels and forks, much of the rest was made with hand held tools and a 60 year old lathe...
Currently the bike has 98 HP at the rear wheels...I made some modifications to the exhaust that should add about 6-8 HP...The two engine make 85  ft lbs of torque @ 5200.....It geared for 165 MPH at 7300 RPM...I think as it is it'll crowd 160 MPH...The 1350 cc gas pushrod class is dominated by Harleys, records at various LSR tracks are 152-172 MPH...
  Here's a video of me putting some heat into the engines and you can see the primary drive
  This is the other Triumph I built........A younger  friend does the riding on both...650 pushrod gas modified production..It currently has the one mile standing start record ,125 mph...The bike has run 129 MPH on a 1-1/2 mile ....
 The bike photographed at Loring Maine just seconds before taking off to set a new class record...
Two of the same engines as that 650, the math says 162.
Go get 'em!
