Holding in clutch, starts creeping forward
Started by Privateer, July 23, 2012, 06:33:13 PM
Privateer
Quote from: ducpainter on August 10, 2012, 06:23:42 AM
Look on the underside to see if the size is stamped.
It is on the coffin models.
here's what I found:
Quote from: Privateer on August 10, 2012, 05:54:03 PM
That adds to my confusion... :P
I'd say 13 mm, but I'm guessing.
Yoyodyne has some pics and listings of kits...with a disclaimer... http://www.yoyodyneti.com/Category.aspx?CategoryID=3016
Give them a call, or use the info to correlate with what you have.
Privateer
Quote from: Speeddog on August 10, 2012, 06:07:51 PM
That's a 12mm master.
thanks Nick.  Do you have a recommendation on where to buy the rebuild kit?
I'd try Yoyodyne first.
Also possible to get it from a KTM dealer, AFAIK.
Privateer
apparently I'm hosed.  Yoyodyne says the masters I have are not rebuildable.
just effing great.
Quote from: Privateer on August 13, 2012, 08:08:55 PM
just effing great.
Check with KTM.
If  that doesn't get you anywhere, give me a call.
I've got a goldline master that's in need of a rebuild as well.
Privateer
thanks.
I dug out my old coffin master to see if I could get that to work so I can at least get back on the road.  Got it hooked up and plumbed, just need to bleed it out real good and see if I can get it adjusted right.
When I was trying to pump fluid down the line when I'd squeeze the lever it would shoot a fountain of fluid out if I let the lever go too quick.  I don't remember that happening before.  normal?
Ddan
Normal, that's the return to let fluid back into the reservoir.
Ducati Monster Forum at
www.ducatimonsterforum.org
Privateer
Quote from: Peggy on August 15, 2012, 02:51:05 AM
thanks.
I guess I don't remember it being forceful enough to hit me in the face.
Now if I could just get the clutch to fully disengage when I pull the lever...
Privateer
Privateer
alright.
some progress.  Apparently I just needed to take the weekend off.
I swapped in my coffin res master and OEM slave cylinder and it seems to run OK, just around the block.  I need a proper shake down to  ensure the clutch is engaging fully, I suppose.
I wonder if the coffin m/c has enough 'power' to push the oberon piston.
I have a call into the local KTM dealer to see if they have rebuild kits.  If they don't reply to my email in the next couple days I'm going to stop by on the way home from work and ask why they're ignoring me.
Privateer
stopped by the local KTM dealer today and explained the situation.  kid at the parts counter found the only 13mm rebuild kit they had and the piston looked NOTHING like the one out of my m/c.  At $36 I wasn't comfortable buying it and experimenting.
I'm starting to get the feeling I'm ass out and will just have to buy a new master cylinder.
Privateer
