February 23, 2025, 07:03:17 PM *
Pages: 1 [2]   Go Down
Author Topic: Hinged rear 'ductail' ?  (Read 3358 times)
« Reply #15 on: August 03, 2012, 01:42:29 AM »
I think a sliding guard would be cooler.
mickb
« Reply #16 on: August 03, 2012, 02:18:35 AM »
...and should I 'motorise' it too, or design a hydraulic mechanism which triggers automatically when it rains  Grin
« Reply #17 on: August 03, 2012, 02:21:33 AM »
This site is always good for a giggle  applause
I need a small (sprung) hinge which would ideally either hold the ductail in a down position, (hinge would therefore be open), but would also be sprung when closed (to hold it behind the licence plate.
Anyone know what type of hinge would do this?
I've never seen a hinge that would do that.
How about a latch for the up position?
freeclimbmtb
From Zero Member to
« Reply #18 on: August 03, 2012, 02:37:29 AM »
BMW R1150R Rockster has a sliding guard...
cant really see it, but theres a flat plastic slide up under that ugly tail that extends down about 4 inches...
« Last Edit: August 03, 2012, 02:45:16 AM by freeclimbmtb » Logged
2011 Monster 796 ABS
mickb
« Reply #19 on: August 03, 2012, 02:55:13 AM »
Thanks DP. If I use a latch for the UP position, what type of hinge would I need so that it would be under tension when its open, I assume the opposite of a standard sprung hinge which uses the tension to close?
« Reply #20 on: August 03, 2012, 03:34:19 AM »
Not sure...
This site may be helpful... http://www.mckinneyhinge.com/catalog/kb.cfm?kb_id=162
« Reply #21 on: August 03, 2012, 03:51:38 AM »
actually a spring attached to it that keeps it up, then a clip that holds it in the down position.
teddy037.3
« Reply #22 on: August 03, 2012, 07:53:54 AM »
I approve of the idea to use a linear actuator to deploy said ductail  Grin
latches? we don need no stinkin latches!
seevtsaab
05 M620
« Reply #23 on: August 04, 2012, 04:27:13 AM »
This is a little more KLR than BMW. I've shortened it a bit since this photo. It can be flipped around up under the tail, or easily removed, it's fastened by two large plastic nuts / bolts. Nowadays the beemer often gets the call when it's raining.
the ductail tour looks promising, I'd be skeptical the sport version would help much.
mickb
« Reply #24 on: August 04, 2012, 10:51:43 PM »
Thanks seevtsaab, yes, I did think the tour version would be more effective, but put the wrong link in my post  Roll Eyes
Pages: 1 [2]   Go Up
