January 14, 2025, 10:50:47 PM
Detroit's Monster Build (conceivably some other stuff to)
8
9
Topic: Detroit's Monster Build (conceivably some other stuff to) (Read 47530 times)
ChrisK
Re: Detroit's Monster Build (conceivably some other stuff to)
Reply #120 on:
November 05, 2012, 08:24:28 AM »
Very excited to see the new taillight set up on the Monster!
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Detroit117
Wings of Steel
Reply #121 on:
November 08, 2012, 02:24:56 AM »
Quote from: kevdawg on November 04, 2012, 06:24:11 PM
Great thread
....I have to grt aroung posting some pics.. I have a 2008 Monster S4RS Tricolore ,, 630 miles on it..( I know,,gott'a ride it!) I also have a 2011 HD XR1200X.. Fun bike!
Keep up the great posts
Thanks
. Those are two mean bikes you listed, would definitely like to see them. Let me know when you get some pics posted.
Quote from: ChrisK on November 05, 2012, 08:24:28 AM
Me to
. I keep tweaking the design, so it is turning out a bit more complicated than I first planned. Just need to make up my mind and fabricate it already.
Detroit117
Wings of Steel
Reply #122 on:
November 08, 2012, 02:25:03 AM »
Shop update:
Sportster 883:
Picked up a lot of the parts I needed. Also, found some time to bolt on the new foot controls. Should get most of the work done on the bike this week.
Side note - I do no have creative control over this project since the bike belongs to my mother. So there will be a few things that I am not thrilled with
. All things considered, the bike will look much better when done.
New rear wheel:
Really like the billet center
Air cleaner (Not the one I would of picked, but not bad):
Mid foot controls:
This side gave me trouble cause of the exhaust. Had to grind down one of my allen keys to get to some of the bolts.
New rear fender:
Shortened it as much as I was allowed. Still need to mock it up and make a few cuts on it before paint.
Rear wiring harness:
I basically need to build a new harness for the back of the bike. The little black box in the left part of the photo below controls the turn signal and brake light functions.
Detroit117
Wings of Steel
Reply #123 on:
November 10, 2012, 05:36:50 AM »
Shop update:
Charger:
Pulled the old suspension out of the car. Going back with a more modern setup from a company called XV Motorsports. Using their level l suspension in front and the level ll in the rear. also getting a custom Ford 9'' rear differential from a place called Strange Engineering, and front/rear disk brakes from Wilwood. Wilwood is putting together a kit for me since my car will technically be a dodge in front and a Ford in back. Getting the master cylinder from XV.
All this and 10.5 inch wide tires will hold me on the road and keep me from dying when I brake or go around a corner in the car.
Links:
Rear suspension:
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=65
Front Suspension:
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=279&cid=38&cdesc=B-Body%20Products
http://www.p-s-t.com/s.nl/it.A/id.163/.f?sc=12
Rear end:
http://www.strangeengineering.net/index.html
Brakes:
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=276&cid=3&cdesc=Brakes
http://www.wilwood.com/
Using the stock lower control arms, spindles, and K-member up front. the ones on my car were junk and no one reproduces them so I had to go digging for some new ones. Lucky for me, I live about an hour and a half away from the largest Mopar salvage yard in the world. Stephen's Performance
, would of had a hell of a time finishing the car without these guys. Also, got some repro. upper control arms while I was there.
My old suspension and the "new" parts I pull out of the junkyard:
Sand blasted and repainted the bits that are going back on the car:
Lower control arms:
Spindles:
K-member:
Repro. upper control arms:
Last Edit: November 12, 2012, 05:35:28 PM by Detroit117
Detroit117
Wings of Steel
Reply #124 on:
November 11, 2012, 02:04:49 PM »
Monster update:
Anyone here ordered parts from AEM? How long did it take to get them?
Got some news from Bellissimoto on my hub. They just got their order in from AEM and my parts didn't show up. So, guess I am going to be waiting a while longer
Should get the material in for my under seat tray soon. Look for some progress on that shortly.
Shop update:
883 Sportster:
Machined a quick adapter for the air cleaner and bolted it on. Disassembled the back of the bike and got a tire / seal put on the new wire wheel.
Turning the adapter:
Had an excuse to use a big drill bit on the lathe.
Bolted on:
Ugly stock wheel:
Gone (what the bike looks like now):
Detroit117
Wings of Steel
Reply #125 on:
November 14, 2012, 07:48:48 PM »
Shop update:
Sporster 883:
Finished and painted the rear fender, installed the new wheel, and made a wiring harness for the back of the bike.
Old fender on right / new fender on left:
The ECU mounts in the fender, so I had to cut out a place for it:
Several pieces that pop rivet on:
Side plate.
License plate bracket.
dust shield.
Wire wheel:
wiring harness:
How the wiring runs under the fender:
Detroit117
Wings of Steel
Reply #126 on:
November 14, 2012, 08:46:51 PM »
Charger:
Welded in a chassis stiffening system designed by XV. Should keep the car from flexing and let the suspension do its job. I know the under side of the car looks a bit rough. Going to strip it and hit it with some spray on sound deadening insulation before the new suspension goes on.
Links:
Engine Compartment Brace
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=18&cid=105&cdesc=Chassis%20Stiffening
Inner Fender Braces
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=299&cid=105&cdesc=Chassis%20Stiffening
Lower Rad Support
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=20&cid=105&cdesc=Chassis%20Stiffening
Sub-Frame Connectors
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=15&cid=105&cdesc=Chassis%20Stiffening
Photos:
Car as it sits now:
Engine compartment brace:
Inner fender brace:
Lower radiator support:
Rear sub-frame:
Front sub-frame:
Sub-frame connectors:
Detroit117
Wings of Steel
Reply #127 on:
November 18, 2012, 09:21:55 PM »
Charger:
Rear diff showed up, has a 3.55 gear ratio. Should be a good performance street setup. Also, had to find and refurbish a set of leaf spring U brackets for my trailing arms. Some idiot that owned the car before me drilled holes in the ones that are on it.
Rear diff:
What I wish my welds looked like
U brackets:
Sporster 883:
Got the rear fender bolted on. back of the bike is pretty much done at this point.
Turn signals / brake lights:
Wiring:
Quick shot of how the new setup looks:
Detroit117
Wings of Steel
Reply #128 on:
November 20, 2012, 06:27:51 PM »
Charger:
Started assemble on the engine for the car. Going to be running a 498 stroker motor, with a 10.5-1 compression ratio. Should make around 525 HP / 625 ft-lbs torque. A place in Huntsville, AL called R&R Speed Shop did the machine work on the block.
Engine block:
Steel 4 bolt main bearing caps:
Eagle crank / H-beam connecting rods / pistons:
Random stuff that was at R&R: billet aluminum V8
Last Edit: November 20, 2012, 06:31:48 PM by Detroit117
Detroit117
Wings of Steel
Reply #129 on:
November 20, 2012, 06:30:28 PM »
883 Sportster:
Better photos of the changes so far:
Detroit117
Wings of Steel
Reply #130 on:
November 26, 2012, 03:05:30 PM »
Going to be shipping out with the Coast Guard tomorrow. That means no updates for the next few months.
gratuitous wheelie photo:
jimbonuttz
Reply #131 on:
January 25, 2013, 12:04:55 AM »
amazing bike and mods, seems like we have similar tastes! can't believe ive never noticed this forum til now
qd xbox exhaust, cw fender eliminator, 14t sprocket, 6k hid, rizoma (front axle slider, rear axle slider, naked prototype mirrors, sports grip, bar ends), speedymoto top triple, woodcraft 3" riser clipons, battery tender
jbuilds
Reply #132 on:
November 20, 2014, 01:03:03 PM »
That's a very clean Monster. Bump.
This build is being featured in the BikeBuilds.net directory here: Monster
We’re currently displaying only a reduced-size photo (similar to what you’d find in Google Images). We'd like to ask for your permission to publish the original full-size image with your build listing.
If anyone would like to have a build of their own listed, just send me a message with a link to the build thread and we’ll take care of the rest.
Cristian
Last Edit: November 21, 2014, 04:05:37 AM by ducpainter
8
9
