January 06, 2025, 07:41:35 PM
Different Rear Brake Lever?
Topic: Different Rear Brake Lever? (Read 2569 times)
Dirty Duc
I'd rather be an anti-
Re: Different Rear Brake Lever?
Reply #15 on:
September 06, 2012, 08:38:53 PM »
I also find this:
http://www.nabd.org.uk/adaptions/adaptionkits.htm#thumb
Ducatis on the Salt
El chucho
Reply #16 on:
September 06, 2012, 10:46:33 PM »
Being the mechanically footed rider,Right BK with Prosthesis, I have researched how. The brembo group makes a rear cylinder with a threaded reservoir fitting (10mm) and you then run a long stainless line From your left grip to the foot brake master, (note: the foot brake master in retracted position is port open, yet the piston will keep fluid from leaking out the push rod end, and will withstand all the pressure from the handle bar master.) Now observe dirtyducks handle bar options, the brembo GP option like Hayden has used, is about $2200, so the dirt bike guys at about $350 are a bargain. Research "thumb Brakes" on general Internet
If you are really "cheap" and handy you can disassemble your push fit foot master and tap the hole for a suitable fitting and save some bucks..
9
Omnipotent Potentate
Personal Pretext
Reply #17 on:
September 07, 2012, 04:07:27 AM »
Here's the kit I mentioned - took me a day to recall where I'd seen it.
http://slavensracing.com/products/brakes/dual-actuated-left-hand-rear-brake-kit-for-ktm-husaberg-husqvarna-by-rekluse
Obviously for the dirt market - but with some craft it could be used for this application. And only $285
