February 23, 2025, 10:09:11 PM
Be your own chase videographer
Topic: Be your own chase videographer (Read 2193 times)
zooom
Re: Be your own chase videographer
Reply #15 on:
September 27, 2012, 04:25:44 AM »
I think if you had a fixed hook from the rear axle that came around the wheel like the rear fender on the new Multi and a swivel at the end of it, you could attach the tow-pole-trailer to it and keep it low and out of the way enough but still have it be high enough that it isn't disturbed by bumps and/or humps...but you still want a little bit of an arc to the tow pole for this same clearance reason as well...but it would reduce the visability of it by a good bit.
2010 KTM 990 SM-T
dark_duc
2008 S4RS Tricolore
Reply #16 on:
September 27, 2012, 10:22:39 AM »
Another option would be to go to a transparent (clear plastic) pole. It would still be there, but not as noticeable.
Privateer
Reply #17 on:
September 28, 2012, 08:31:21 PM »
that's pretty awesome. hooray for ingenuity.
