February 24, 2025, 03:23:01 AM
Please Help
BST wheels for my S2R (pics)
Topic: BST wheels for my S2R (pics) (Read 4268 times)
S2R 800 '07
Re: BST wheels for my S2R (pics)
Reply #15 on:
October 21, 2012, 10:41:56 AM »
Different tire manufacturers make different profiles - my 190 Metzeler M5 is about the same shoulder width as a 180 tire from another manufacturer (can't remember which one). The point is that a 6" wheel should have a 190 tire to maintain the shape that works. I hope you find a 190 tire that fits - much better result - you deserve best result with those wheels!
Still can't tell from the photos - is the conical spacer there? Is there a spacer between the wheel and hub?
Hershell
Reply #16 on:
October 23, 2012, 05:24:19 PM »
Love the wheels, good job.
2017 Superleggera 1299
2014 Monster 1200S
2013 Panigale 1199R
2016 Yamaha Zuma 50
Reply #17 on:
October 23, 2012, 05:44:44 PM »
needtorque
Reply #18 on:
October 24, 2012, 03:40:16 AM »
190 vs 180 is about 0.2 inches added to the width on each side of the tire. It is not much wider and would probably fit but just be close.
Who insures the FDIC?
Rowdy
S4R
Reply #19 on:
October 29, 2012, 02:17:17 AM »
I might be the lone ranger here but I think you should paint them white.
You greatly underestimate the amount of overconfidence I have.
Kirk Allen
Reply #20 on:
February 15, 2013, 11:57:51 PM »
Hi Stopintime, I finally switched to the 190 rear tire. New Pirelli Supercorsa, there is a still a lot of clearence!
S2R 800 '07
Reply #21 on:
February 16, 2013, 12:40:57 AM »
Quote from: monstro72 on February 15, 2013, 11:57:51 PM
Good to know
Top speed will make the tire expand, diameter, so depending on where your eccentric hub is positioned (chain length, wear, sprocket size) I suggest keeping an eye on the tire just to be 100% sure there is no contact against the front section of the swingarm.
Reply #22 on:
February 16, 2013, 02:26:24 AM »
Quote from: stopintime on February 16, 2013, 12:40:57 AM
Good to know
wouldn't that depend on tire shape and tire pressures
S2R 800 '07
Reply #23 on:
February 16, 2013, 08:53:43 AM »
Quote from: Raux on February 16, 2013, 02:26:24 AM
Maybe - I don't know....
I contacted a couple of manufacturers with the question when I switched from 180/55 to 190/55. Only Metzeler replied and the answer was reassuring - can't remember exactly, but I believe it was 4 or 5 mm expanded radius at 275km/h. Other manufacturer's tires might perform differently - if so, the eccentric hub position
can
become a critical factor - at least in theory.
SpikeC
Spike in PDX
Reply #24 on:
February 16, 2013, 06:15:27 PM »
Ah, the bigger tire just slows your turn in!
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
