The ORIGINAL Bacon thread & ALL things bacon-related!!!
Started by IZ, May 06, 2008, 11:37:49 PM
Bacon Wrapped Chorizo and Cheese Stuffed Jalapeno Poppers Smoked With Cherry Wood
Blackout
2006 Ducati Monster 1000
2003 Honda CR250
2008 KTM 990 SuperDuke
Kopfjäger
Blackout
2003 Honda CR250
Randimus Maximus
I saw that there are now multiple brands of  [bacon] jerky on the market today.
Discuss.
Breakfast Bacon Cups
Ingredients:
White or Wheat Bread
Bacon
Shredded Cheddar Cheese
Eggs
Butter
Maple Syrup
Salt & Pepper
(Note quantities not added. This will vary depending on how many you plan to make. It's safe to estimate about 2-3 per person. )
Pre-heat oven to 400 degrees. While the oven is pre-heating partially cook the bacon for about 3-5 minutes in a large skillet set to medium-high. You want the bacon to be a little cooked but still pliable. Mix maple syrup and butter in a small sauce pan and heat over medium low so butter melts (you can't mess this up so don't worry about amounts too much. I usually use ½ a stick of butter and a cup or so of syrup).
Using a cookie cutter, ravioli cutter, or whatever else you may have that can cut a 3 inch diameter circleâ€"cut circles out of the bread slices.
Here comes the good part! Grease/non-stick spray muffin pan and line with bacon so that is circles each mold. Now, brush each side of the bread with the syrup/butter mixture and place in cup so that it rests evenly at the bottom of the mold. You may have to do a little trimming of the bread but it's ok if it doesn't fit perfectly either. Crack an egg into each mold, season with salt and pepper and give each cup a sprinkle of cheese (you can also add the cheese on top of bread, beneath the egg).
