led turn signal resistors
Started by sofadriver, November 11, 2012, 06:57:37 PM
suzyj
Quote from: ungeheuer on November 28, 2012, 01:40:36 AM
My LED turn signals do some weirdness.
With the motor running, they flash a the correct rate.....
.... but if I flip the turn signal switch with just the ignition on they flash at blown bulb speed  ???
And even weirder.... they didnt used to do that when I first installed 'em (nope cant remember how many ohms my resistors are).
I'm not stressing about it coz they flash at the correct rate when I really need 'em... but I do wonder if some electronic damage is afoot.
The chip doesn't just sense blown bulbs. It also senses over current, over temperature, and low battery volts.
At a guess, you've got a dodgy connection between your battery and gauges, with significant voltage drop under load. Enough to trip the low vbb sensor on the driver chip when the bike isn't running...
Just a guess.
Quote from: suzyj on November 28, 2012, 01:46:43 AM
Just a guess.
I have low battery volts.  Still the original stock (3 year old item), spasmodically tendered, parked idle more than it runs lately.
Explains why I now get hypo-flash until the motor is making juice  [thumbsup].
You good  [bow_down].
