Good deal or no??
Started by ruffrider, December 16, 2012, 05:21:53 PM
zooom
Quote from: ruffrider on December 17, 2012, 01:11:26 PM
How do I attach photos so you guys can see the bike. I have a couple close ups of the rear end to maybe give you guys a better idea of how clean this bike is and why it's so difficult to forget about...  ;D
http://www.ducatimonsterforum.org/index.php?topic=109.0
2010 KTM 990 SM-T
You have to host them at photobucket, flikr, or the like and link to them.
ruffrider
Here goes nothing. Im not sure if i did it right...
muskrat
Nothing is right.  Try again.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
ruffrider
I got the links up to view the pics. I couldnt figure out the other way...  :-\  Let me know if you can view them and what you think of the conversion and the bike from what you can see. Thanks!
Well, that looks way nicer than I expected.
Pedro-bot
Some help
Looks nice!  [thumbsup]
One item of concern that is apparent to me is the exhaust.
You may not find it an issue now, but changing out the exhaust may prove somewhat of a challenge. Short of the QuatD there isn't much out there for your custom SSS monster that is an easy bolton.
Any other exhaust configuration may need some "tinkering."
Dirty Duc
Pedro has more XP with the flickrs... but I add two more
Pedro-bot
Quote from: Dirty Duc on December 17, 2012, 08:25:30 PM
Nah, I just can't see that well anymore.
Sheer necessity.   :P
BTW, OP, I would be interested to see what the pivot site looks like on the frame. The part of the frame the shock bolts onto.
ruffrider
Wow thanks for putting them up. And ya, I figured I could make my own exhaust. I do a lot of fab work and was mainly concerned about the noise and compression loss I would have with the straight pipes. Yes I am wanting to see the fab work in person and the shock mount as well. I'm going to try to find time to drive and look at it this week.
118811
Really want to see pics!!!
MadDuck
118811
#28
Whoa
I like it....paint looks good , great wheels and with that SSS ....if it runs & rides good...
I would probably go for it!!!!
Put a shorty Akrapovic can on there and go..... [clap]
ruffrider
Well... I bought it. I couldnt turn it down. Its a solid bike. But i did notice some things when i got it home and in my garage.  Cons: Leaks oil just a little when running, notice some oil that has been sitting on the motor as well, Rear sprocket is a little loose( everything else is tight but the sprocket wiggles back and forth), rear wheel was a hair loose and had some play between it and the axle(I tightened axle nut and it went away), Needs some electrical work to get all the custom blinkers and intigrated tail light to work perfect, and shes really cold blooded, hard starter when cold. Other than that stuff, which i think is not too big of a deal??, its a great first ducati in my opinion.
