April 27, 2024, 01:21:26 AM
loctited allen bolts on belt tensioners
Topic: loctited allen bolts on belt tensioners (Read 10954 times)
muscle_cars_only
Re: loctited allen bolts on belt tensioners
Reply #15 on:
July 07, 2008, 03:27:46 PM »
For the future when dealing with RED loctite.
Use a soldering iron rigged up to sit inside the head of the allen. Then hit with an impact that has a good bit in it. If you use an iron that will go up to 900 degrees you don't need the impact.
02 Speed Triple Black 16k
04 CBR600 F4i Red/Black 8k
06 m620 Red
