April 29, 2024, 08:10:10 PM
How to: DucatiDiag
5
8
Topic: How to: DucatiDiag (Read 115259 times)
Enjoying the ride
Re: How to: DucatiDiag
Reply #30 on:
March 11, 2013, 09:13:35 AM »
double checked everything, all checks out, just, wont give those screens for testing, should I connect to bike and test connected to bike?
worst case scenario, I need a new ECU after the test or ?
JohnEE
Why not
Reply #31 on:
March 14, 2013, 08:37:03 AM »
Quote from: Darkmonster620 on March 11, 2013, 09:13:35 AM
DucatiDiag won't bring up the test screens? Worst case is you need a new ecu, though if you have checked out the power connectors you should be all set.
08' S2R 1000
Enjoying the ride
Reply #32 on:
March 14, 2013, 11:00:51 AM »
Quote from: JohnEE on March 14, 2013, 08:37:03 AM
My Centurion S for IAW5AM connects perfectly . . . so DucatiDiag has been uninstalled . .. best $250.99[inc s&h] I have spent !!!
JohnEE
Why not
Reply #33 on:
March 14, 2013, 11:44:25 AM »
Yeah, some people have a hard time getting connected other people plug in and don't look back. Glad to hear it's not some obscure electrical gremlin keeping you from diagnostic testing of your ECU.
08' S2R 1000
OzzyRob
Reply #34 on:
March 14, 2013, 03:11:57 PM »
I'm reading this as you haven't connected all connectors to the bike. That's not what you mean is it ?
Enjoying the ride
Reply #35 on:
March 30, 2013, 08:00:41 PM »
Quote from: OzzyRob on March 14, 2013, 03:11:57 PM
no connection to bike . . . period!!!
vij
Reply #36 on:
April 01, 2013, 11:14:21 AM »
Quote from: Darkmonster620 on March 30, 2013, 08:00:41 PM
Did you read what is written on the DD forum? ? ? ? ? ?
First of all I hope that you have a VAG-COM KKL 409.1 OBD2 USB Cable and nothing else.
You have to install the following ftdi driver as most VAG cables do not come with a proper USB to serial converter that is required.
http://www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe
You should run windows 7 in Windows XP compatible mode.
Then it might work better.
Last Edit: April 01, 2013, 11:16:32 AM by vij
vij
Reply #37 on:
April 01, 2013, 11:28:30 AM »
Quote from: xsephirot on March 11, 2013, 08:16:18 AM
So if you want a tune, you would just dyno your bike get the AFR ratio and adjust accordingly with the program? Does it also tune each cylinder separately?
Ducatidiag is a diagnostic software. With this you can diagnose your ECU, you can also extract the map from the ECU.
After you have extracted the map you use the free software ECU. With ECM (software that works together with DD) you can change any single parameter that you want in the map so yes you can do individual mapping. You can of course optimize the ignition too.
The you have to pay 100 Euros to get the flasher. With the flasher you can upload the new map to the ECU.
All you need is cables for 30 euros, flasher for 100 euros and you have a complete ECU mapping software. Included in the 100 euros you also have access to a very large bank of Ducati stock and Ducati performance maps for free.
DD, ECM and the flasher works perfect. It also means that if your ECU goes tits up you can get a cheap one on ebay and flash it with your old map and not pay the enormous amount of money that Ducati wants for an spare ECU.
DD rocks
Jocke.......
Enjoying the ride
Reply #38 on:
April 01, 2013, 11:39:49 AM »
Quote from: vij on April 01, 2013, 11:14:21 AM
Did you read . . .
<snip>
Are you trying to tell me something?
vij
Reply #39 on:
April 02, 2013, 11:23:44 AM »
Quote from: Darkmonster620 on April 01, 2013, 11:39:49 AM
It is not very clear what interface you have, what driver you have installed, if you are running in XP compatible mode, if you are running in fast or slow init, which ECU type you have.
Jocke.......
JohnEE
Why not
Reply #40 on:
April 11, 2013, 07:05:27 AM »
I have acquired the writer so i can flash my ECU to DP spec
Also i have reset the TPS and played around with the trim. But I forgot to take screenshots like a dummy. First post will updated in day or two depending on the rain.
08' S2R 1000
JoeP
Reply #41 on:
April 11, 2013, 11:16:46 AM »
Quote from: JohnEE on April 11, 2013, 07:05:27 AM
Let us know if the speedo calibration works and if the odometer is still correct afterwards.
xsephirot
Reply #42 on:
April 12, 2013, 08:40:02 AM »
Oh keep us posted! Maybe just set up a video camera for the whole process so we can get a general idea how this stuff works. I've tried to read that forum and even the english section is kind of hard to understand.
JohnEE
Why not
Reply #43 on:
April 14, 2013, 12:29:59 PM »
Updated 1st post with TPS, TRIM and writer how to.
Quote from: JoeP on April 11, 2013, 11:16:46 AM
I didn't use this feature as i think my speedo is pretty close to actual.
08' S2R 1000
Mr.Purple
Re: Re: How to: DucatiDiag
Reply #44 on:
April 30, 2013, 01:36:10 AM »
Genius software! Flashed my ecu with the writer program.
And the engine runs so much smoother with the DP ECU
5
8
