February 24, 2025, 08:29:33 AM *
Pages: 1 [2]   Go Down
Author Topic: Vance & Hines slipon, undoubtedly the best for Monster 796 (NEW-8 photos added!)  (Read 8004 times)
Andyind
« Reply #15 on: March 27, 2013, 11:17:01 PM »
I think the joints are tight enough, and held by springs and clamps properly. But ofcourse since it is a metal to metal fit, there may be leaking gaps. I will have to check carefully for leaks there.
I need to remove the pipes for service, so that these guys here don't screw my warranty!
I live in Tamilnadu, South India
Enjoying the ride
« Reply #16 on: March 28, 2013, 08:43:44 AM »
I think the joints are tight enough, and held by springs and clamps properly. But of course since it is a metal to metal fit, there may be leaking gaps. I will have to check carefully for leaks there.
Ok, so, your warranty is voided if they see the exhaust YOU installed? Do they enforce such tight restrictions? Someday from you will get tired of installing/un-installing those pipes and you will ride the bike like it is right now; or, one of the guys at the dealership will see the bike with exhausts.
I live in Tamilnadu, South India > OK, please, ride the bike checking your temperature, if it runs within range, then the ECU is adjusting accordingly; then if you want, just to test, install the K&N filter, remember, DO NOT use octane boosters that are not O2 sensor safe, this, just in case you are planning or using octane booster or any other fuel additive, even better, stop using them.
If when you install the K&N filter, you see that the temperature stays in the upper range and popping is constant, revert to your OEM filter. This means the ECU is not able to adjust for the extra amount of air coming in.
If I am wrong in something, please, someone chime in . . .
bob795
« Reply #17 on: March 28, 2013, 10:08:51 AM »
(snip)  remember, DO NOT use octane boosters that are not O2 sensor safe, this, just in case you are planning or using octane booster or any other fuel additive, even better, stop using them.
What would happen if octane booster that is not O2 sensor safe were used? I was going to buy octane booster and carry it on my next ride, just in case I can only find regular gas (89 octane). Does it say "O2 sensor safe" on the packaging/bottle?
2011 Husqvarna TE 630
2012 Monster 795
2002 Sportster 883/1200 (sold)
Enjoying the ride
« Reply #18 on: March 28, 2013, 10:15:55 AM »
bob795,
it has to say "Oxygen sensor safe" . ..  if not, you might damage the O2 sensor
bob795
« Reply #19 on: March 28, 2013, 10:20:28 AM »
Thank you very much Darkmonster620  waytogo Now I know what to look for.
2012 Monster 795
Enjoying the ride
« Reply #20 on: March 28, 2013, 10:21:52 AM »
You're welcome
Billyzoom
I'm having much more fun.
« Reply #21 on: April 12, 2013, 06:21:47 AM »
Ooooooooeeeee!   That looks very very badass.   waytogo
Andyind
« Reply #22 on: April 12, 2013, 08:06:06 AM »
I really love the pipes. They look great and sound fantastic! all heads turn my way when I ride. And when I decelerate and stop, to meet a group of friends or for a traffic light, it is pure adrenaline! The whoorrrrrmm and decal pops - you have to ride it to believe it!
Pages: 1 [2]   Go Up
