M696 Have a bug?(starting issue)
Started by kokis, May 20, 2013, 08:23:51 AM
Unfortunately your problem is intermittent so it won't be that easy to find.  Cary a meter with you and try to test while the problem is happening.  Think of it as a voltage "goes into" problem.  Goes into the solenoid but doesn't come out, bad solenoid.  Goes into starter, no crank, starter problem.
kokis
I found it. Starting problem - corroded kill switch.
Starter problem - starter contact was not covered with it's rubber cap and corroded. [roll]
I am not pro in tech questions, but as any rider have some experience that I can share without claiming to absolute truth. Please use my advices responsibly.
