HUGE ISSUE EMERGENCY!!!!!!
Started by adpeacock, June 03, 2013, 06:26:43 PM
if it's overfilled and fresh clean oil, it may look like no oil because there is no top line?
OzzyRob
Quote from: Raux on June 03, 2013, 10:20:05 PM
That's a damn fine point sir.
adpeacock
Before the problem I could see where the top line of the oil was.  So I am confused is this a huge issue?  Should I ride it today?
-2005Monster 620 Dark, Monsterparts Carbon Fiber Beer Tray, Pazzo Levers, Dunlop Qualifiers, CF Front Fairing
"Japanese Bikes are like supermodels; great to look at but full of aftermarket parts."
IMO it is not a huge issue. It isn't going to blow up. It will continue to push oil into the airbox until the level goes down.
It could start leaking somewhere if you have a gasket that isn't perfect.
If you have a turkey baster and a piece of tubing you can connect to it you can remove some oil through the oil fill.
In the future when you change oil put about 3/4 of the recommended amount in and then start the motor and shut it off after a warm up and check it in the sight glass. Top it up as necessary. Very few Ducs will take all of the recommended amount.
adpeacock
Okay thanks a lot for the help guys.  This was a huge help to me.
Be sure that you are checking the oil level in the sight glass properly. Which is on level ground, with the bike upright - NOT leaned on the side stand.
El-Twin
Quote from: Slide Panda on June 04, 2013, 05:33:32 AM
On my 1100evo, just a few degrees off of true vertical makes a surprising difference. It can easily go from showing too low to showing too high with just a slight list to one side or the other.
Since I don't yet have a proper stand in my inventory, I stabilize the bike with bungee cords attached to secure fastening points, then carefully place a 2x4 under the side stand and measure for true vertical with a long bubble leveler against the back tire. I can then calibrate the lean angle with smaller bits of whatever material is handy placed under the sidestand.
It's very Rube Goldberg, but effective and accurate. (And cheap... working strictly with native household elements  :)).
1961 Honda 50
1962 Mustang Thoroughbred
1972 Honda CB500 Four
2012 1100 evo
If I ever find myself on a winding road, holding up a line of cars with a motorcycle, I will carry the shame to my grave.   -PETER EGAN
SpikeC
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
El-Twin
Quote from: SpikeC on June 04, 2013, 10:29:43 AM
Good solution El-Twin!
Thank you, sir.  [thumbsup] I thought so hard about it that I could actually smell wood burning.  ;D
1961 Honda 50
2012 1100 evo
Cloner
Are you sure you're not seeing the sight glass completely covered with oil?  Is it oil colored, (brown or red or whatever color you used) or is it clear where you can see the shiny metal baffle behind it?  I have seen crankcases so full that the oil is well above the sight glass, even when sitting on the side stand.
The "required amount" is too much for a bike that hasn't been completely drained....which is impossible during a "pull the drain plug and change the oil filter" service.  ALWAYS fill the oil to the recommended level between "full" and "low" on the sight glass, not to some theoretical required volume.  This also applies to forks.
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
Cloner
Oops....guess I might have looked at "Page 2" before posting....
Still applicable, I suppose.
'04 KTM 450 EXC
memper
I sit on the bike with a carpenters level on the tank and read the window with a small mirror taped to a yardstick.  [clap]
Heath
You guys are making this too complicated. Hold the bike upright with your right hand on the throttle, bend down and look. No levels, no wood shims, ect...   Or just get a Baxley sport chock ;D
2007 Ducati Monster S4RT
OzzyRob
Spot on heath....I've always done it that way......that what I thought everyone else did
Or get someone else to hold it upright
HotIce
I keep the bike right up, grab the iPhony, and snap a picture  ;D
