I've tried searching this everywhere. Is it a direct swap frame wise?
I believe it'll be close. I recall there's a frame tube near the vertical barrel that's dimpled for clearance on the S4Rs bikes that (I think) isn't on the S4R bikes. I'm also fairly certain that the cross-bracing above the front motor mount bolt is the same... Rest of it will be interchangable as far as I can remember...
Of course, you'll need an S4Rs motor to do it for the swingarm pivot width.
