December 01, 2024, 02:10:12 AM *
Pages: 1 ... 8 9 [10] 11 12 ... 23   Go Down
Author Topic: Homemade mods  (Read 294932 times)
Skyshadow
'01 Monster 750 Dark
« Reply #135 on: December 20, 2011, 11:05:46 AM »
hey so then you getting rid of your Remus high-mount? Can you let me know when you do cuz I want high-mount exhaust
Yea, actually I am going to sell those. Haven't decided on how much yet though.
- Homemade Exhaust
- K&N filter
- Tail chop w/ integrated tail light
- Sliders
My rear brake is just for looks.
Skyshadow
« Reply #136 on: December 20, 2011, 11:24:19 AM »
Also, here is my thread over it...
http://www.ducatimonsterforum.org/index.php?topic=54261.0
- Homemade Exhaust
- K&N filter
- Sliders
sebastienb
« Reply #137 on: December 29, 2011, 08:41:53 PM »
get ready for the cheapness.  i made my own set of adapters for pod filters.
i used two pvc pipe fittings like the one below,  but i cut them in half so that all im using is the threaded part.  they are smooth on the inside and didnt have any changes in size through the part i was using so i figured it couldnt be too bad.  the size of pvc i used was for 2in pvc pipe on the non threaded end.  i measured the outside diameter of the threads, and found a corresponding k&n filter that fit, and also measured the ammount of room between where they mounted and the bottom of the tank so i could fit the biggest ones possible under there (6 inches).  the part number i used for the filters was ru0620 (im 99% sure)
and how it looks on the bike.
Back in the days I used to want to use PVC pipes for car cold air intake systems but was always told that PVC fumes are bad for the engine and it will get hot under the hood. If you do stick with PVC male sure it's rated for high heat.
Nero-92
« Reply #138 on: January 11, 2012, 12:31:18 PM »
Here's a few pics of the cafe racer style seat cowl painted and fitted to my s4 there's just a wee cushion to be made to fill the gap between cowl and seat to finish it of but I'm quite pleased with the results so far.
I am a bog snorkeler
Skyshadow
« Reply #139 on: January 11, 2012, 12:45:36 PM »
^Not bad. not my style though
- Homemade Exhaust
- K&N filter
- Sliders
J-Speed Inc.
« Reply #140 on: February 05, 2012, 07:14:37 AM »
put some pod filters today and modified the air box so that it is just a battery box
I did the same thing on my 99 M900.  Just make sure you make a support for the front of the airbox now that it's supporting all the weight of the battery and ignition components on just the two rear bolts.  I used two tubing clamps which are screwed into the front of the battery box and attach to the horizontal frame tube that is in front of the battery box.
Nero-92
« Reply #141 on: February 08, 2012, 04:52:31 PM »
Just made a handle bar end bracket for the duc and took it for a test ride can see more than my shoulders now ab fab. Here are some pics.
Skyshadow
« Reply #142 on: February 09, 2012, 06:44:39 PM »
Can I see a pic from further away, they look huge in the pics lol
- Homemade Exhaust
- K&N filter
- Sliders
« Reply #143 on: February 09, 2012, 11:54:32 PM »
nicely done. stock mirrors huh
Nero-92
« Reply #144 on: February 11, 2012, 12:03:50 PM »
Yeah stock mirrors waste not want not and heres a pic further away.
Skyshadow
« Reply #145 on: February 13, 2012, 06:32:58 PM »
Nice! I bet you can see a lot in those. I'm guess you cant lane cut in your state though?
- Homemade Exhaust
- K&N filter
- Sliders
Fireman1291
Firefighter/EMT
« Reply #146 on: February 21, 2012, 01:17:52 PM »
I was bored and had some heat resistant caliper paint. So I masked it off and used one of my wifes triangle makeup sponges to apply the paint. It worked out great.
2012 Monster 1100EVO Black/grey
118811
« Reply #147 on: February 21, 2012, 01:56:41 PM »
Attention to detail!! chug
Fireman1291
Firefighter/EMT
« Reply #148 on: February 21, 2012, 02:56:30 PM »
Thanks! It really ads a lot. Your eyes are drawn to the massive brakes now. Looks factory. chug
lawmaster891
« Reply #149 on: February 25, 2012, 10:53:50 PM »
Relocated my fusebox from under the seat to the battery box. Relocated the regulator and rerouted/rewired looks much more clean.
Pages: 1 ... 8 9 [10] 11 12 ... 23   Go Up
