Fueling issue?
Started by lazylightnin717, July 19, 2013, 06:29:49 PM
lazylightnin717
Anything I should do with the electrical connection to the fuel pump while I am in there? It seems awfully exposed..
Waiting for a new o-ring from Feracci for the tank flange. The one I got from DT several months ago ended up being too big  [bang]
Any tricks to getting that back on without pinching it?
Comes a time
Says don't you see
Gotta' make it somehow
They seem to work fine as is.
Grease the o-ring. it's next to impossible to install the flange otherwise.
lazylightnin717
What am I not understanding about this?
Is the o-ring not supposed to sit in the groove?
Comes a time
Says don't you see
lazylightnin717
#19
2nd time around..
Can you anybody confirm the part # of the correct o-ring?
Is it possible that I have a different tank and need a different size o-ring than the normal S4?
:edit: looks like McMaster carries several different sizes. I would be willing to go that route too.
Comes a time
Says don't you see
I'm coming up with 886.4.011.1A O-Ring
What's wrong with the old one?
Yes, 88640111A is the O-ring for all steel Monster FI tanks.
That looks like the O-ring for the fuel pump flange on a 916 or the like.
I'd go with this one:
http://ca-cycleworks.com/products/maintenance/gaskets-o-rings/or-40111a
There's a pic showing how it fits.
lazylightnin717
That's the part number that I came up with and the same one Ferracci pulled.
I cross referenced and all of the steel tank Monsters use the same o-ring.
Me thinks they screwed the pooch on this one.
They asked me to send them pictures and told me they would call me back. I never got a call back.
Quote from: Speeddog on July 26, 2013, 08:28:52 AM
That's definitely the one I need. What a dumb hold-up this is  [roll]
Comes a time
Says don't you see
lazylightnin717
Comes a time
Says don't you see
Quote from: lazylightnin717 on July 26, 2013, 05:04:51 PM
It was old  :P
Allow me to be crude...
If it fits the cap holder...
use the make the beast with two backsing thing.
Clean it off...reinstall it, grease i,t and use it.  ;D
lazylightnin717
 [laugh]
I forgot to mention that I threw the old one away...and I'm not goin' dumpster diving in NJ.
Needless to say, I ordered a 5 pack of Viton o-rings from McMaster for $8 and it worked like a charm. Bike fired right up and everything looks to be good for now.
I might go back in with new fuel line for the overflow. They look a little funky in there
Comes a time
Says don't you see
