Well its been almost 3 years so I figured I would update the post. A lot has happened with the bike. It was stolen for a short period. They never got it started, but managed to roll it down a huge hill and hit a giant curb at the bottom damaging the rotors and the wheel. Somehow the forks and front fender were also damaged. The bike was found in the woods nearby with the ignition drilled out.
It was sad
Now on to the mods
Ducabike clear clutch cover
Ducabike Levers
Ducabike rearsets
Domino Racing throttle/grips
Vortex clipons
Diesel rear seat cover
I also used a grinder to remove the instrument display mount from the headlight and painted it black. It now resides in the radiator cover and has for quite sometime without issue. My state does not require it either. I used a cheap set of metal files to get what was left over smoothed out.
Front blinkers removed. Main reason being with no dash, no indicator to let me know I've left it on. Last thing I need it someone to think I am going left and turn out in front of me. Also not required by my state.
Decent weather is just now arriving, so I promise to get some quality pics soon.
Took 3rd place at the Monster Challenge!
This was after adding clipons, but still mostly stock:
I decided the dash stuck out like a sore thumb so I took a grinder to the mounts and tried some custom aluminum sato racing mounts. Eventually they broke on me... while riding...
I used dupont accessory paint on the headlight, turned out kind of a matte color, I didn't care for it.
Then I decided to finally take the leap and try and split the wiring harness and relocate the dash to under the radiator cover. My biggest concern was if anything was going to generate enough heat. I have since rode in 90+ temps without any damage to the display.
Before the Diesel seat cover, and Domino racing throttle. Added Ducabike goodies.
Finally got the cables fed in through the top of the headlight, Diesel seat cover installed
