Ducati to starting fresh with GP14?
Started by duccarlos, September 29, 2013, 11:33:24 AM
zooom
Quote from: Raux on October 01, 2013, 10:33:29 PM
when the got rid of the trellis with the 1199, they could have jumped ship then with the new engine design, and gone full force into the D16 era.
it was a half measure and I think it's going to burn down their wsbk race program.
+1
2010 KTM 990 SM-T
gm2
agree as well.  but making a 4-cylinder street bike that they produce en masse, since that's what they'd have to do, well, might as well change the name of the company.
and then they'd still get their asses handed to them for a few years since clearly their track record with 4s is stellar.
Like this is the racing, no?
duccarlos
Triple J
A V4 street SBK still is a bit different than an in-line 4. Only Aprilia makes one currently...a company that also primarily made twins, and they seemed to do well with it.
I like twins and all (especially for street bikes), but it appears their days are numbered in SBK racing.
Spidey
Isn't it basic engineering?  Twins suck for racing unless they are racing against other twins.  V4 does not suck for racing and neither does I-4.  Unless you have rules that make up for twins deficiencies (and a boatload of $ to keep those big twins from exploding), they can't compete.  And it's hard to get the rules right so that you don't weigh too much in favor or too much against a twin.
I don't know that changing to a v4 SBK would make Ducati any different.  I used to think that the trellis frame, dry clutch and twins were sacrosanct.  But change happens. <shrug>
Maybe they should look at 16v twins. (Honda NSR style oval pistons)
Triple J
Here's the problem with twins in racing as I see it (and any of you all can correct me if you'd like, as I'm sure you will  [laugh]):
Twins disadvantage is they are inherently down on power to 4 cylinders. Their advantage is their power delivery is in inherently easier on tires (and a kind of built in traction control) and they have more torque to get better drive out of corners. These two things mostly offset their power issue, as they can drive harder out of corners and keep a higher pace over race distance.
Four cylinders advantage is they make more power so are faster on any straight section of track. Their disadvantage is they deliver that power in constant fashion to the rear tire (you can actually feel this riding a twin back to back with an I-4), which eats tires and will more easily highside the rider if they try to get a big drive out of a corner. The result is diminishing pace over race distance, and less drive out of corners.
Prior to electronics these adantages/disadvantages largely offset each other. Some tracks favored fours, while others twins.
Electronics have now fixed the four cylinders disadvantages. For instance, they reduce the number of working cylinders on corner exit so it acts more like a twin (BMW does this for sure), so better drive and better tire wear and also full power on straights. The problem for twins is while the electronics can fix the four cylinder's inherent shortcomings, they can't give the twin more power.
Spidey
Twins also seem to grenade with a frequency that 4 cylinders don't seem to.  To really hop up a twin requires a really costly maintenance schedule.  It might just be that in order to compete, twins need to be hopped up way more than 4 cylinders, which leads to more blown engines, cases, etc.
(yes, I know that Aprilia went through 28 engines or sumptin' when Max won).
Triple J
The Ape started down on power to the 4s in stock form though, explaining the motor changes as they've had to really build it to win in WSBK. I think the lower HP is just an issue with the current iteration of that motor, not with V4s in general. Aprilia is supposedly fixing it next year.
The I4s are friggin' stupid now. My motor builder said he has seen a new ZX-10 lay down 200 hp at the wheel...with only a map and exhaust!  :o
zooom
well, the "Evo" class rules may level some of the unparity of electronics for the engine configurations as JJJ stated...
2010 KTM 990 SM-T
ChrisK
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
zooom
1st) it will take several years before the effect of Gigi's changes will trickle from GP to the WSBK program IMHO
2nd) it will take at least half of 2014 GP season to see measurable results from Gigi on the GP14 machine IMHO
2010 KTM 990 SM-T
gm2
Quote from: zooom on October 10, 2013, 07:17:41 AM
that is a logical statement but i wouldn't be surprised if you're wrong.
zooom
Quote from: gm2 on October 10, 2013, 12:00:24 PM
it wouldn't displease me to be wrong...but knowing how they have to fabricate and design and test and analyze data and everything else...the GP13.5 to be debuted at Sepang post season won't be as much as an advance to the GP14...where I expect to see things really change is when the GP14.5 comes about....
2010 KTM 990 SM-T
thought
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
