What did you just buy for your Bimota?
Started by SpikeC, October 15, 2013, 07:21:07 PM
SpikeC
#15
 ZARD!!!
 A set just arrived from Italy with NO cats!
Now to get some nice ceramic coating on them, maybe the shiny kind.........
  Ok, I skipped the coating and went ahead...... It turned out that there was only one cat, and it was in the middle of the front header. The other two parts were the same as were on the bike, so I just installed the front pipe, it starts easier and runs smoother in the 3-4k range, so a worth while improvement, however, it now sounds like a jalopy!
I keep looking for something loose, butt everything is nice and tight!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
SpikeC
 It turned out that there was a plug missing in the pipe, got it installed and now it sounds like a proper Ducati hotrod!
A package just arrives from Areostich with an EarCannon air horn that is going in next!
I'm really having to look hard to find things to do on this thing!
Spike Cornelius
  PDX
   1965 T100SC
PolyesterPig
For my Bimota DB4ie I bought LSL bar risers, new stainless brake lines, Ducati 999 radial brake and clutch masters, Gianelli exhaust, posted heads, custom machined throttle bodies with knife edged butterflies and machined down butterfly shafts, PC3 and new tires.
[shot]
SpikeC
Spike Cornelius
  PDX
   1965 T100SC
Ducatamount
half fast
SpikeC
 I just received a set of MWR air filters for the DB5R. They look really nice, pre oiled and everything! Now I have to remove the tank and body work so I can also install the Ear Cannon!
Next up will be a set of those fancy-dancy wires for the starter circuit and ground, then the Shorai.................
Spike Cornelius
  PDX
   1965 T100SC
SpikeC
 I installed the MWR air filters and they appear to work nicely, the bike feels stronger and the fueling seems fine.
The big deal is the HICAP II starter cables! When starting from cold it would really labor and require 3 tries to get running, now with temps in the 30's it jumps into life in less than a second, like it was fully warmed up! What a huge difference those cables make!
The air horn is fitted inside the fairing on the left side and it makes a lot more noise than the stock one, butt when a car was close to invading my space recently I blipped the throttle and got the same result as a loud horn, the driver look up and moved over!
Spike Cornelius
  PDX
   1965 T100SC
SpikeC
 Ok, I didn't buy this, I made it. For controlling the heated jacket.
Spike Cornelius
  PDX
   1965 T100SC
That machining is beautiful (the clamps) [drool]
SpikeC
 Thanks, koko, there is more of it elsewhere on the bike!
I just got an Eclipes tankbag and it fits like it was made for the bike! Lots of capacity, expandable, and the mounting system is very easy to manipulate, unlike the Givi strap setup.
Spike Cornelius
  PDX
   1965 T100SC
seanster
dang...everything is so nice...even down to the kick stand.   [thumbsup]
SpikeC
 The level of detail on this thing is insane!
Spike Cornelius
  PDX
   1965 T100SC
abby normal
The fuel tank ... Is that polymer or metal?
1990 851 bp
2004 S4R
1997 YZF 1000R
1987 NT650
2010 BMW s1000rr
2013 848 evo corse se
SpikeC
 :'(  not metal. there are a few ally ones out there somewhere.  this one seems to be working ok tho........
Spike Cornelius
  PDX
   1965 T100SC
SpikeC
 EVR gold clutch slave cylinder! Blingy-blingy! it goes with the forks and wheels, tho.........
Spike Cornelius
  PDX
   1965 T100SC
