April 28, 2024, 02:57:19 PM
OZ monsters
M800/620 forks....
Topic: M800/620 forks.... (Read 3575 times)
brad black
Re: M800/620 forks....
Reply #15 on:
December 28, 2013, 08:26:18 PM »
I think it's finished now.
I would expect all the 43mm Marzocchi to be the same, but that can only be confirmed by physically inspecting them. none of the photos in the manuals are the same as these ones. maybe they're showas in the manual, now that I think of it.
Brad The Bike Boy
http://www.bikeboy.org
suzyj
Does my bum look big on this?
Reply #16 on:
December 29, 2013, 02:11:38 AM »
Cool summary Brad. I've never understood "progressive" springs, as even linear springs are nowhere near linear in actual use.
Actually this is a good argument for the longest spring possible, with no spacers, to keep the force curve straighter.
brad black
Reply #17 on:
December 29, 2013, 03:24:42 AM »
linear would be linear if not for the impact of the internal air pressure rise. it's effectively a dual spring system, both adjustable to some extent, but one intrinsicly not practically removeable. you can remove the spring, some of the mitos were like that (one leg only?).
the actual physical spring is somewhat irrelevant apart from the rate and having the correct preload, as long as it doesn't bind before full compression.
Brad The Bike Boy
