January 04, 2025, 12:33:08 AM *
Pages: 1 [2] 3 4   Go Down
Author Topic: New Speedymoto Clip Ons  (Read 8732 times)
desmoworks
« Reply #15 on: July 14, 2008, 05:17:02 PM »
Yeah, let's see some rearsets now!
They are working on it, among other things... Hopefully the rear sets will be out in the not too distant future. I'm not sure if they will have them for the Monster right off the bat. I know they are talking about having them for Superbike first.
Anthony Creek
Pro Italia Online || mota-lab
« Reply #16 on: July 14, 2008, 08:08:07 PM »
They will... I'm installing mine this week on my 675. I received these in 50mm and 53mm already.
SWEET!  Let me know how they work out.
DucSteve
Hey Yo
« Reply #17 on: July 15, 2008, 11:59:57 AM »
those look nice.  whats difference between 50 and 53?  width or length?  which for s2r? thx
OwnyTony
« Reply #18 on: July 15, 2008, 12:52:02 PM »
they are the measurements on the forks. If your forks are 50mm, than the 53 would be too big and you would need shims. If your forks are 53, the size 50 will obviously be too small and you would have to bore them out.
Sorry for stating the obvious.  Depending on what bike you have, we will know what size forks you have. On the s2r800,1000 and i think s4r, the top part of the fork is 50
DucSteve
Hey Yo
« Reply #19 on: July 15, 2008, 01:06:12 PM »
I figured that's what they stood for, thanks.  So 50mm would work then?
c_rex
Quick! Into the transmogrifier!
« Reply #20 on: July 16, 2008, 12:28:04 PM »
Blackducky- update mang?   Wot's that dealership doing, knitting cozies for the clip-ons?  Pict-chers not belly ic-tchers please.  Grin
OwnyTony
« Reply #21 on: July 16, 2008, 12:56:13 PM »
Yes, you would need the 50mm.  You can verify this by looking at your forks with out measuring them.  on the s2r forks, bottom of the triple tree are wide, i think 53.  The top tapers down to a 50.
desmoworks
« Reply #22 on: July 16, 2008, 04:34:31 PM »
54mm at the bottom. 53mm bottoms are generally on SBK forks (along with 53mm tops).
Anthony Creek
monsterRS
« Reply #23 on: July 24, 2008, 07:59:06 AM »
I heard from a parts guy at Motocorsa in Portland that there have been some problems with these clip-ons on monsters.  Apparently they have a clearance issue with the headlight bucket.  Anybody with some experience with this want to confirm?
MotoCreations
« Reply #24 on: July 24, 2008, 08:30:41 AM »
Confirmed.  SpeedyMoto is making Monster specific clipons to address the situation asap.
monsterRS
« Reply #25 on: July 24, 2008, 08:41:58 AM »
Thanks!  I guess I'll wait.
DucSteve
Hey Yo
« Reply #26 on: July 24, 2008, 08:59:46 AM »
can't wait for some reviews popcorn
squidwood
« Reply #27 on: July 26, 2008, 04:10:33 AM »
the clip ons will not fit the s2r for certain.The issue is the clearence with the two brackets that hold on the headlamp.There are two bolts on the bracket that interfere with the hinge of the clip on.This is being worked on as we speak and as soon as a practical solution is made I'm sure Speedymoto will let you guys know.Please bear in mind that they make lots of other parts and have to keep the supply of those going while they address this issue, so , unfortunatly its not going to happen overnight, but they are well aware of the situation and are working on it.
BTW the clip ons will also fit most bikes using that diameter fork.
hydra
life is analog...
« Reply #28 on: July 26, 2008, 10:07:10 AM »
hey squidwood,
will they work on an S4 with a cycle cat triple and their bar adapters? i was thinking of these clip ons above the triple onto the bar adapters...
S4 Foggy- tires, battery...
BE WATER
moto
« Reply #29 on: July 26, 2008, 05:20:08 PM »
We mounted the SPEEDYMOTO Adjustable Clip-ons: 50mm on the 696--you have to loosen the headlight to fit the clip-ons and then put the headlight back in place.
It is pretty low under the triple.
Clearance:
Here is both mounted so you can see the difference:
To mount it on top, you will need to lower the front.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
Pages: 1 [2] 3 4   Go Up
