there's a guy in adelaide that's revving a 696 based race thing to 12 from memory.
high revving 2v is a bad idea for a road bike imo. big, heavy valves beating the shit out of the valve train. you need to fit an 848 evo motor into it. then you could rev it. and have no midrange, just like an 848 streetfigther.
800 pistons are 2.25mm shorter in the comp height compared to 750, due to the 4.5mm stroke difference.
how much money are we spending? 90 is quite a it from an 800 or less cc motor.
I was thinking of going with a bigger bore as well, not sure that would make much of a difference
I have found hi comp pistons for 750/800 but no big bore kits
as far as high revving I was meaning 10-11k
a previous bike 900 SS I had was built to 944 with MBP heads and ST2 cams and split FCR's it would still be pulling past 10k
wish I still had that bike
as far as money not sure since I am going to do it bit by bit
probably not more than 3000-3500
anymore and i might as well invest in a different bike
you mentioned a 900 block with 748 crank would be stronger, but does that mean that a 800 block is weak ??
people race those right ??
