well....
since I am not made of money and the bottom end arrived yesterday
I will have to stick with the 800
the 800 heads will be arriving next week
I will send those out, probably to Bruce Meyers
if I need to keep it under 10k rpms maybe it wouldn't be necessary to have the crank work done
but I would love to have it lightened and balanced
I was planning on carillo rods though
not sure where to locate ST2 cams they seem to be hard to come by
I thought the 800 heads already came with carbie cams
Brad you mention a "real" 6 speed trans in the bigger case motor,
why is that?
are you referring to the close 1-2-3 gears and spread out 4-5-6 ??
which is preferable, close ratio or wide ratio ??
the Loud bike mentioned above ended up with the 5 speed trans
I spole to the guys at AF1 yesterday and they seem very cool,
plus they have a dyno and are set up for custom mapping etc.
anyway anymore insight would be appreciated
building a hot rod motor on a budget seems like an oxymoron
to be continued
