January 23, 2025, 06:04:55 AM *
Pages: 1 ... 9 10 [11] 12 13 ... 33   Go Down
Author Topic: M944SS build  (Read 113410 times)
« Reply #150 on: August 13, 2014, 04:25:02 PM »
I don't why I keep doing that. Damn Mods with single syllable N names...that I have starkly different rapport with hehe.
It's because I'm old and cranky...
and Nick isn't as old...or cranky. Kiss
Rudemouthsky
Autonomous red and black
No gods and no masters
« Reply #151 on: August 15, 2014, 06:56:57 PM »
Did the red LED mod in the nos cluster;
The coolant idiot light that gives away that this is an S4 dash is bothering me. Just seems tacky. Luckily the "plate" from the correct 600/750 dash has a part # and it's only $20. Since that's the last thing making this cluster completely correct since the tach is a DP mechanical one for a carbed bike I've gone ahead and ordered it.
Rudemouthsky
« Reply #152 on: August 17, 2014, 04:04:37 PM »
I adore the RR exhaust and I'm somewhat committed to it, but it is going to need some serious overhauling to be suitable for this bike. Drilled out the rivets and pulled this giant turd out:
The whole thing needs gutted and re-done. There's like 3 chambers of baffling all wrapped up in some cruddy steel wool. All that is going in the trash in favor of a straight perforated tube wrapped with some fiberglass. There's some posts on the "other" board detailing this a long with much improved flow and a better exhaust note. And I have a local metal guy making some new end caps out of aluminum, and all will be ceramic coated. So this piece of poo will be made worthy.
Rudemouthsky
« Reply #153 on: August 18, 2014, 05:56:29 AM »
Hmmm...maybe MH900 exhaust tips/end caps?
thorn14
« Reply #154 on: August 18, 2014, 06:57:49 AM »
Same diameter?
And yes to gutting it. Smiley
M620 turned M800 but then back to M620 after the M800 died at 110k, and now to Multi 1000.
Rudemouthsky
« Reply #155 on: August 18, 2014, 07:08:13 AM »
Same diameter?
I don't know yet, I've messaged the seller.
I'm trying to wrap my brain around the concepts of exhaust scavenging and the need (or lack of) for some kind of crossover within. I guess RR must have had a reason for this odd design, but all of the anecdotal forum info I come across says this exhaust is not good for power (which I can attest to) and it needs to be "gutted" for best results. "Best" meaning what tho? I always felt like this thing did a nice job on my 750 at the low and mid range so I don't want to sacrifice any of that grunt chasing more peak power. I also don't mind a loud exhaust obviously, but as loud as this thing is already I can't even imagine having nothing inside. I'm thinking of straight perforated tubes with a fiberglass packing wrapped around it, and new tips like the ones pictured with a spark arrestor grill.
Hopefully some exhaust gurus will chime in?
monsta
Perth, Australia.
« Reply #156 on: August 18, 2014, 05:25:49 PM »
I've found scavenging VERY important, but the RR exhaust has it.
But cant say how good it is.
I had that exhaust on my bike for a while and found that it didn't have much clearence.. I could grind it down in a school zone!   Grin
« Last Edit: August 18, 2014, 06:34:43 PM by monsta » Logged
Rudemouthsky
« Reply #157 on: August 18, 2014, 06:22:49 PM »
This is one of the posts that inspired me to work on the exhaust;
My  friend had them.
You have to totally clean of content them to make them work and then they are loud.
His  W2 -98 w 39mm FCRs & pods, polished heads w DP cams & HC made 88 RWP, mine made 82 w V2 & 41mm, SS cams & HC on same dyno.
Still find it hard to believe that it made those numbers w those small valve heads, although I sen the chart dozens of times. Shocked
Rudemouthsky
« Reply #158 on: August 24, 2014, 04:12:16 PM »
Diggin this carbon bucket so much I may sell some plasma and get the matching brackets.
Rudemouthsky
« Reply #159 on: August 24, 2014, 04:18:49 PM »
Got impatient and put the front end together...
Experienced some drama...my speedometer drive is not a suitable spacer for this wheel, but the provided one from Carrozzeria worked. On one hand I'm annoyed but on the other, I guess it's time to ditch the idea of an OE dash (more money wasted  bang head ) and get the Trailtech Voyager I decided I REALLY want. Cheesy
GPS...speedometer...tachometer...and way more. The perfect James Bond dash.
http://www.trailtech.net/digital-gauges/voyager-moto-gps
monsta
Perth, Australia.
« Reply #160 on: August 24, 2014, 06:55:10 PM »
niiice!  waytogo
Where'd you get the headlight bucket?
Rudemouthsky
« Reply #161 on: August 24, 2014, 07:21:36 PM »
niiice!  waytogo
It's a Motowheels bucket, guy was selling it new on eBay for some reason, nabbed it for $80. I guess he didn't like it!
thorn14
« Reply #162 on: August 24, 2014, 07:22:38 PM »
make the beast with two backs that's delicious.
Rudemouthsky
« Reply #163 on: August 24, 2014, 07:34:52 PM »
Check out the features of this thing. It's geared toward off road riders but I think it'd be great for anyone who has one swiss army bike for commuting, adventuring, canyon carving cafe hopping etc. I'd use the crap out of it. And it looks fantastic. Way more fitting for this build than the clunky analog clocks. That billet protector comes in clear, black and red too. Smiley
memper
« Reply #164 on: August 25, 2014, 07:32:10 AM »
No, the contrast is good. Be careful not to get too matchy matchy.
Pages: 1 ... 9 10 [11] 12 13 ... 33   Go Up
