Exhaust 1100 EVO question / popping
Started by Radracer6, May 21, 2014, 08:04:53 AM
DexterMorgan
I just had my 1100 Evo Dyno tuned yesterday.  I have the stock ECU, BMC filter and comp werkes muffler.  I first had the ECU  re-flashed like you did.  This allows the tuner to tune the ENTIRE rpm range.  If you buy the PC-V for the 09-11 1100 you will not use the supplied o2 optimizer.  Mine is still in the box.  I now have NO popping at all, but i do ride with the db killer in so i know that helps a lot.
-Adam-
2013 Monster 1100 Evo
2013 Monster 796 (wife's)
Radracer6
Dexter thats what i was looking for, nice. I have the DB killer in as well. Did it run better with the map on the PCV or did you just have them tune it right when it was put in?
DexterMorgan
It runs a million times better now.  I did try it without the db killer but i like the sound of it with it in.
-Adam-
brad black
there's no idle mixture setting function in the conti ecu like there is in the marelli 5am the sport 1000 had.  so you can't do that after you've turned off the lambda sensors.
i've found a few of the rexxer maps for the contis to be very lean at idle, and how they run overall is just a function of how good the mapping is and its suitability to your bike.  generally, i always found on bikes that were set up in the same consistant method had very good consistancy with preset mapping, ie, back in the eprom days.  but the new bikes without idle trimmers and the like can be a bit inconsistant at times.
i richen them up if required, but it depends what access the flasher has to doing that side of things.  you can also do it via the bazzaz or pcv, which is what would be done if you had either of those fitted.  while fitting the o2 optimisers or whatever each company likes to call their version if them does help there, disabling the lambda sensors in the ecu software is the most consistant in terms of stable result.  it's just an extra cost step.
Brad The Bike Boy
http://www.bikeboy.org
Radracer6
Cool thanks very much for the info. Since i have the reflash alreay I am going to add the bazzaz. Haven't decided yet if I'll take it to a dyno once installed or get the ZAFM *AutoTune for it.
oldndumb
#20
Radracer6,
PowerCommander and Bazazz almost do the same thing, but each has its hardware and software differences. Just wondering why you picked Bazzazz?  ???
re the popping and DB killer effect. I run the CompWerks DB killer but I enlarged the opening after several AutoTune remaps made it evident that the popping intensity and frequency were decreasing. After the last remap a few days ago almost all of the popping is gone.
Radracer6
#21
Read both about PCV and Bazzaz both seemed like good options and both have an AutoTune add on. Chose the bazzaz because i read good things on the ducati and gixxer forums, but mainly also because another member sold me a used unit at a good price.
So my decision once I install will be either to dyno tune the bike which I assume is around 400-500 bucks or add the bazzaz autotune and self map for 250. I am also curious to see how it will run on the map bazzaz provides as well before that.
Old did you set your traget AFR at 13.0? Did the PCV software smooth the data? Thanks
oldndumb
#22
Your decision was made too easy by a friend offering you a good deal.  ;) Myself, I almost had analysis paralysis trying to read everything I could about both and speaking extensively with their sales and tech people. I finally went with the PC based on the hype that an O2 for each jug was better, and I had a friend who attended the PowerCommander training classes. As for the sensor for each jug argument, the Bazazz people can counter that position with seemingly factual info. No doubt in my mind that they are probably equally effective. One thing that the Bazzazz has in its favor is the software interface. Much more modern and intuitive.
I've set my AFR for 13.2 based on talking with PC. I have taken a few trips with it set to 13.6 at the higher throttle percents and RPMs for fuel economy. On long highway runs you can tell the difference in miles before getting the light. Yes, the AutoTune smooths out the tables. I have mine set to a low default of only ten percent at a time. That way, I can accept the changes without needing to precisely examine each cell for any outrageous (piston holing) changes. This meant going through the process frequently at first, but it is easy and only takes about ten minutes.
Using an autotune feature, you can fool with AFRs at all settings if searching for performance. Myself, performance is a bonus because my objective is smoothness or drivability, although spell check says that isn't a word.  ;D
Deciding between an autotune vs a dyno session is easy. If a measurable performance gain is your objective, a dyno session is better 99.9% of the time. An autotune will enable the bike to run more as designed, but the only data comes from your butt dyno.....but you will definitely feel it.
Radracer6
Yea i dont really care about squeezing the last bit of power from this bike. Just want it to run right, get rid of the popping and smooth it out like you said.
Radracer6
Any of you guys install the PCV or Bazzaz yourself? Any tips? We're you able to get to all the wiring propping the tank up or did it have to come off completely?
Barney
I attempted to install the bazzaz myself and go about halfway thru before I couldn't access clips anymore: i dont recall what they were for, but i have giant gorilla hands and didn't have the proper tools.  I ended up having it installed when I had my valves done not too long after that.
12 M1100EVO
09 KTM 200XC - sold. I cried.
70 Honda 450 Scrambler
Radracer6
Hi, so I wanted to submit an update on this. Today I installed the bazzaz, the injector connectors were a major PITA, I had to remove the batt box to get at the rear. Overall it too me 3-4 hrs mostly because of these hard to get to connectors, rest was easy. I installed the bazzaz auto tune AFM as well.
I decided to start self mapping from scratch so this is with a clear map. I have the MW reflash ECU with o2 removed and CW slip on. I went on a quick 20 minute ride and then looked over the AFR data. Most of the cells I was able to fill during this run were up to about 50% throttle and from 2.5 to 5k rpms.
So it seems me thinking the bike was running really lean is backed by the data. In all the cells I filled the AFM shOwed the bike was mostly in low 15s AFR. The suggestions were to add a lot of fuel in most of the cells, some around 20 or more percent. I smoothed the data however in the application to smooth any such big changes.
Now let me tell you, just from one run I definitely feel a big difference. The popping on deceleration and high rpm coasting was deceased by about 85 percent. I was popping nonstop before even some random backfiring. Now it is mostly gone. The bike on throttle feels more full, acceleration is so smooth now.
One other thing I noticed is the engine seems to get hot slower. On the same route I would hit 4 bars on my 1100 about half way, now it's running mostly at 3bars, then it will hit 4 toward end or when I hit city. Very pleased so far going to do a few more tunes.
Here's a pic of my initial tune, mind you the values are smaller because I used the data smoothing function
Radracer6
For anyone that is interested here is my final map with the bazzaz self tune. Bike was running really lean down low and below 50% throttle, rich up on big throttle openings. It is so smooth now it's shocking, this is the best mod I've ever done.
2012 1100EVO with MW reflash, removed exhaust valve and O2 sensors and CWerkes Slip On in NYC.
brad black
can you do each cylinder individually?
the autotuning tools are really going to help a lot of people.  this is how i used to do them on the road, and you get really good results this way.  you just need to sneak up on your target so you don't get an overshoot hystric thing going, and once you have a good basis you can always start moving back to a leaner cruise, etc.  if you can do both cylinders then you can make them amazingly nice: smooth, powerful and economical.
altho these days location and heavy speed law enforcement out here means it's not practical.  most people will be amazed how little time they spend with the throttle open in a non open road environment.
Brad The Bike Boy
Radracer6
I believe the powercommander lets you tune each cylinder individually but could be wrong. The bazzaz doesn't as far as i know but lets you tune each gear if you want. I'm very happy how smooth it runs.
