January 06, 2025, 06:29:54 AM *
Pages: 1 [2]   Go Down
Author Topic: JohnEE's S2R1000 Project  (Read 11622 times)
MotoPsycho
General Nuisance and a
My Dream, my rules !
« Reply #15 on: April 27, 2015, 09:13:58 AM »
That's exactly how I felt. Bleh.   vomit
At least that one has information on it though. Not a speedo connected to a giant box with 5 lights in it.
JohnEE
Why not
« Reply #16 on: May 16, 2015, 03:20:10 AM »
When maintenance needs and mod wants combine.
I haven't changed the paper filter since I got the bike. I finally got the DP map(The ECU fairy  Wink ) so I could switch over to pods and get rid of all that black plastic!
This is the corse dynamics kit from Moto Wheels. Decent kit. Was sorta a PITA to install, the air box was awkward to remove. The bracket for the coils is a tight fit between the fuel line and a branch of the harness. Getting the velocity stacks into pods took effort. Everything just took a lot longer than I expected for a simple mod. Also no instructions, you have been warned. I need to cut down that idle air filter tube.
I found some more tubes to pull off, the PO did the charcoal delete but left the tubes to the intakes attached and plugged the 1 into 2 hose with a nut. I need to find out what screw can plug into the intakes.
As for performance wise, I didn't really notice any difference with the butt dyno. Sounds a lot cooler though, haha. I did it more for getting rid of the giant black box more than performance so it works out.
Pages: 1 [2]   Go Up
