January 10, 2025, 10:29:12 AM
Miles Per tank
Topic: Miles Per tank (Read 5536 times)
dufukincati
Re: Miles Per tank
Reply #30 on:
June 19, 2014, 03:26:09 AM »
Yeah the ecu profile was tweaked. If I'm cruising I'm usually at 4-4.5k RPM. What is your riding style?
dbran1949
2007 S4RS Black Termis
Re: Miles Per tank
Reply #31 on:
June 19, 2014, 06:29:17 AM »
Riding style fairly aggressive weekend back country, occasionally ride to work San Diego
dufukincati
Re: Miles Per tank
Reply #32 on:
June 19, 2014, 09:06:38 AM »
Do you spend a long time above 7k RPM?
dbran1949
Re: Miles Per tank
Reply #33 on:
June 19, 2014, 12:48:38 PM »
only the occasional blast above 7k mostly stay in the 5 to 6k range
dufukincati
Re: Miles Per tank
Reply #34 on:
June 19, 2014, 03:39:05 PM »
The power band is pretty flat between 5k and 6k, so are you really gaining much by cruising there? I ride around at 4k because that is the slowest engine speed i can maintain without obnoxious vibrations. The hills here are pretty tame, so the engine never seems to bog when climbing them. My sprockets are 14/43 btw. Lower engine RPM leads to better fuel economy .
Is your air filter clean?
YMMV, cheers and enjoy your S4RS..
dbran1949
Re: Miles Per tank
Reply #35 on:
June 19, 2014, 04:23:48 PM »
It's in for 15k service so air cleaner will get replaced. I'll see how it does after. Same 14/43 here
thanks for the info
