Clutch Master How to bleed
Started by Kabulpostie, June 19, 2014, 09:08:01 PM
I've seen that on a brand new Ducabike slave, bad part.
Replacement was OK.
I've had one customer get two bad DP ones, in a row.
brad black
turn the bars all the way to the right, then lean the bike over to the right so that the clutch lever is higher than the banjo bolt at the outlet of the master.  don't spill fluid everywhere.  then pull the lever in many times, slow then fast (watch for spurting fluid), short then full range, etc.  that often helps.  you can see the air as it comes out.
spurting fluid is a real danger.
Brad The Bike Boy
http://www.bikeboy.org
Quote from: Curmudgeon on June 20, 2014, 07:43:01 PM
Ohhhhhh...., that's your callsign?  ;D
Maybe you should warn him what brown shoes do in bars!  8)
Eh. Not quite. Was an enlisted squid for 5 years and, after 2 years stationed at a MC airbase, decided I'd had my fill.
But if you're looking for brown shoes vs black shoes fun, here you go:
