S2r 1k forks on s2r 800 advice
Started by cbcanada, October 25, 2014, 09:49:01 PM
Quote from: The Last In Line on November 13, 2014, 04:56:04 AM
All  S2R800 Dark = 2Pot small calipers as used in M620 Dark/M695, as per DCS
FTFY  :D
Quote from: Speeddog on November 12, 2014, 11:25:14 PM
Quote from: ducatiz on November 12, 2014, 08:05:55 PM
the calipers on the 800 are identical to the calipers on the 1000.
exact.  same. part.
Ducati used the same calipers on almost all their non-superbikes between 99 and about 2005.
Wut?
Yup.  Between 99 and 05.  Notice i excluded some bikes and said "almost".
05 was the first year of the 2piston crapolas on thw s2r800, and the radials on the S4rs, but the 4-piston/2 pad brembos were still used on the S2R1k.
prior to 05, all the SS bikes, Monsters, MTS, etc had the same brembo 4-piston, 2-pad setup with 320mm rotors in front.
SBK had a variety of calipers, but bottom end models had them too.
exact.  same. part.
~~~SNIP~~~
That was the part that was unclear, especially in the context of an S2R800 thread.
Quote from: Speeddog on November 13, 2014, 02:00:31 PM
Ah.
I was replying to the m800 comment above.  My bad.
cbcanada
One last question.. With all your help I got all of the pieces needed for the front end rebuilt and will start a new thread on the actual rebuild soon. But I am just curious should I upgrade the rear shock to now perhaps two are 999 rear shock? Or is there a need to any suggestions?
Ride the bike with the new front a while first.
Maybe/probably you'll find out that the shock has become the weak link.
Good luck  [thumbsup]
cbcanada
Quote from: stopintime on December 13, 2014, 06:30:12 PM
Will do. Don't forget to keep an eye out for my new front end rebuild thread to guys I'm going to need all your help over the winter :-)
