October 03, 2024, 09:18:09 PM *
Pages: 1 ... 14 15 [16] 17 18 ... 57   Go Down
Author Topic: Truckers Monster Rebuild  (Read 298561 times)
truckinduc
« Reply #225 on: September 02, 2010, 08:30:34 AM »
na its actually very simple. ill give you another hint.
truckinduc
« Reply #226 on: September 02, 2010, 08:32:54 AM »
« Reply #227 on: September 02, 2010, 08:33:25 AM »
sheeeeeet
you aren't turning that too much!
Scooter-Trash
« Reply #228 on: September 02, 2010, 08:48:23 AM »
ahhhh.. you instibated the circular confabulator and the modular kreason has too much heptalagular radius...
I believe the hexaform compression unit would be adversely abrading the aforementioned heteroclitic axial retention unit.
TAftonomos
is without a monster :(
« Reply #229 on: September 02, 2010, 09:09:33 AM »
Pretty clear now....thought the flange for the nut was the same depth as the ring.
oops Smiley
DucHead
No garage queens
« Reply #230 on: September 02, 2010, 09:35:55 AM »
Too bad, I really liked the eccentrics.
Can' you use a longer axle with a spacer behind the nut?
(Love this thread BTW.   waytogo  )
truckinduc
« Reply #231 on: September 02, 2010, 05:16:08 PM »
bingo.  It was a stupid mistake because I started making the pieces before I had the axle.
I like these too but its ok because version 2 will be even better. I made these manually, the new set ill knock out on the cnc.
truckinduc
« Reply #232 on: September 02, 2010, 06:48:26 PM »
started parts of the mockup swingarm.  the funny thing below the axle is a tool I made today.
it takes shitty things like this
and spins like this
which results in a nice flat and true face like this
so these can press in nice and flush, after coating.
also Im making one of these.
Baileigh TN-250 Tube & Pipe Notcher with Radial Vise Tubing Notching Pipe Coping Machine
Howley
« Reply #233 on: September 03, 2010, 12:47:09 AM »
Loooove this thread!
truckinduc
« Reply #234 on: September 05, 2010, 04:51:00 PM »
so anyone wanna tell me why I need a reed valve in my crankcase breather when none of my other bikes have a reed valve?
truckinduc
« Reply #235 on: September 05, 2010, 05:36:43 PM »
Here is why I ask.  I am designing my rear subframe mount and it would be better if I could make a smaller breather with no reed valve inside. The breather will be fed into my subframe for additional volume and then into the airbox.
Im going to take a guess and say the valve will close under negative pressure and help assist the other piston down. But is there ever really negative crankcase pressure?
Mojo S2R
. Dark Mojo .
« Reply #236 on: September 05, 2010, 09:59:36 PM »
Someone correct me if I am wrong.  I believe it's to prevent overflow.  I have a custom breather valve on my bike that does not have a reed valve and have not had any problems or overflow.  Though I don't do wheelies and this may be where it would become needed.
« Reply #237 on: September 05, 2010, 11:12:50 PM »
apparently the old TT F1 didnt have a reed valve. it had a oil seperater box in the tail under the batter. It allowed the oil to drain back into the case without blowing it out.
it was basically a two-chamber box with a air passage that stopped oil blowby.
a hose would run from the case to the box hidden.
« Reply #238 on: September 06, 2010, 02:05:45 PM »
None of the pantahs have a reed valve.
The crank vent nozzle has a short labyrinth which, combined withe the longer hose, does nearly the same job.  Reed works better with a short hose.
truckinduc
« Reply #239 on: September 06, 2010, 03:26:12 PM »
well all in all the subframe, about 5 feet worth, should collect any oil on its inner walls and let it drain back down.  I ran for a long time with a bart simpson head on the breather with holes cut in it. never had oil puke out, just a slight residue after 1000 or so miles.
I guess im more interested in the performance of reed valve vs no reed valve.
Pages: 1 ... 14 15 [16] 17 18 ... 57   Go Up
