Wrapped my exhaust and trimmed the tail a bit
Started by WestonWith2, July 13, 2008, 04:28:58 PM
roy-nexus-6
Quote from: azmonster on July 15, 2008, 09:45:50 PM
Generally, you use header wrap to wrap headers, not mufflers. Tend to actually work a lot better.
Don't tell me that - I'm about to do the same thing :D
I've painted the pipes already - will wrap the mufflers: purely cosmetic.  [thumbsup]
55Spy
Quote from: roy-nexus-6 on July 16, 2008, 03:19:14 AM
When/if you wrap anything wrap it back to front.  It leaves the exposed lip of the wrapping free from fraying from wind/debris hitting it at speed.  (you can feel the difference if you run your hand across it from front to back)  trust me I have wrapped so many headers on my offroad bikes  got to do it several ways and see how each held up.  also slightly damp wrap will pull tighter.  tuck the last bit under at 45 degrees so you don't have a raw cut exposed, and but a set of safetywire pliers and safety wire it vs the clamp.  It'll look way clean and holds up well.
WestonWith2
Quote from: 55Spy on July 16, 2008, 03:54:39 AM
Good tip... now that I look at mine I see I wrapped mine with the edge heading into the wind. We'll see how it holds up.
roy-nexus-6
This is all excellent advice. Thanks!
I've never done it before, but I figured a damp wrap would tighten up. But I hadn't thought of using safety wire - so I'm thinking I'll definitely go that route!
Cheers  [beer]
NekkedChic
I am frustrated with appearance of header pipe on my 696...SO wanna PC it, but too much $$$$ right now.
SOOO, any help on wrapping at least the ONE silly looking dipping front header pipe is MUCH appreciated here. ANYone???  Did a search for info/thread, found this only.
TK YOU
Ducatista Barista
w7ck7d
Quote from: NekkedChic on January 13, 2009, 06:19:41 AM
TK YOU
I just got my 696 headers wrapped up .looks clean.and i was thinking about wrapping my stainless termi 2 .and hear it its somebody already did wrapped the muffler.pic on the way
09' 696 Black
94' BRONCO 5.8 EB
w7ck7d
Quote from: WestonWith2 on July 13, 2008, 04:35:33 PM
Let's try this again...
Looks good.I was thinking about doing this n my stainless termi muffler .since ive just done wrapping up my headers.
09' 696 Black
94' BRONCO 5.8 EB
Mojo S2R
Nice job Weston.  Looks good.  I like what you've done.  I say wrap the pipes too and paint the shields black to match the rear hugger, and since you've removed the reflectors what about pulling those frame stickers too.
ProTeal55
Member: Half Fast Chicago
Website:
Mojo S2R
#26
w7ck7d,
Put [_img_] in front of the url and [_/img_] behind the url (just don't add the underlines)
Like so...
[_img_]http://i69.photobucket.com/albums/i46/w7ck7d/my%20696/IMG_0137.jpg[_/img_]
When you take out the underlines so that the coding is correct you get this:
Oh, and to make sure you have the correct url just right click the image, select properties, copy the address from the popup and paste that url into the code.
w7ck7d
can anyone tell me how to upload pictures here???thank you
09' 696 Black
94' BRONCO 5.8 EB
w7ck7d
09' 696 Black
94' BRONCO 5.8 EB
NekkedChic
Looks SOO much better with header pipe wrapped. GOTTA get mine done! Anyone live near me and good at it, need some extra cash?!
Stupid question???   Is it OK to remove ugly frame stickers, btw?  Is there a REASON for them where they are or a law?  I am in Florida.  Tks.
Ducatista Barista
