January 06, 2025, 01:29:14 AM
Bored, so I made some carbon...
5
6
Topic: Bored, so I made some carbon... (Read 12805 times)
flanman
Re: Bored, so I made some carbon...
Reply #30 on:
July 28, 2008, 04:12:48 AM »
Im interested in both TAftonomos and truckinduc projects. When you finish the project a how to step by step guide would be cool
hypurone
Reply #31 on:
July 28, 2008, 05:36:40 AM »
Dealer has no take-offs!
So at this point it's gonna cost us to buy one (hopefully used and cheap). TAftonomos, any idea on your costs to make these or if it is even doable? It is a rather complex part with the TB openings and such. Also, we need to get an open top as well, hopefully a used airbox will have a top that can be modified.
truckinduc
Reply #32 on:
July 28, 2008, 05:49:22 AM »
mine is a 3 piece design. You have the airbox, then what you would call the lid on the stock box which holds the filter, then the removable ram air piece which slides in from the front of the bike right below the lower triple tree.
The filter is mounted in a very different way but it creates more air box volume than stock.
The filter element itself will be a K&N made for a suzuki car.
TAftonomos
is without a monster :(
Reply #33 on:
July 28, 2008, 06:03:41 AM »
Quote from: truckinduc on July 28, 2008, 05:49:22 AM
Yours is going to be a LOT different than what I need/Testa motor.
To really get a good idea on it, I need to take a good look at mine and see what I can come up with.
It might be easier for me to start with a foam plug and go from there. Increasing the airbox volume is never a bad thing either.
I think moulding the base of my airbox, then going from there with a foam plug, glassing, sanding, more glass, etc... to come up with a plug to make a mold from.
MyDucParts.com
truckinduc
Reply #34 on:
July 28, 2008, 06:20:30 AM »
im starting with foam and shaping it to fit. Then i will get it just right and use it as a plug. Ill also be re- locating my battery and coils slightly. I wont be using anything off my old airbox except the rubber grommets used to connect the carbs to the airbox.
Once the mold is done it will be easy to re-create airboxes, (as im sure you know) to sell.
My biggest problem with the stock airbox is all the litttle details on the outside. Those would be hard to replicate in carbon as it doesnt want to drape that easy. I figure the best thing for you to do would be pull a mold from the inside of the stock box.
Reply #35 on:
July 28, 2008, 08:25:26 AM »
Hmm...taft...building your own breatherbox... GOOD IDEA. i just wish i knew how to use lay carbon fiber or fiber glass, never worked with either.
I already made everything to eliminate the breather box. Made a mounting bracket for the regulator, and also picked up spark plug wire so i can relocate and change the color of my wires (red). Would love to see what you come up with!
Beyote
Reply #36 on:
July 28, 2008, 12:05:49 PM »
worthless without pics.
truckinduc
Reply #37 on:
July 28, 2008, 12:24:47 PM »
im not giving away my design
jesse370
Reply #38 on:
July 28, 2008, 12:43:04 PM »
a carbon airbox for a Rs would be....titties!
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover | Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
hypurone
Reply #39 on:
July 28, 2008, 12:53:13 PM »
Quote from: jesse370 on July 28, 2008, 12:43:04 PM
BETTER than titties, cuz you could fondle/sleep with it and not get into any trouble with the GF/SO/WIFE!!
truckinduc
Reply #40 on:
July 28, 2008, 01:32:00 PM »
once my prototype is done ill probably make some to sell if i think i could sell 5 or more. I just have to get my hands on a s4Rs first.
weemonster
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Reply #41 on:
July 28, 2008, 02:23:34 PM »
very nice but its not real c/f is it.
Its Carbon matting in resin. looks nice but isnt much lighter than g/f and is no use at all for structural parts
Its not pukka. layers layed in a mold then cured in an autocalve. which iw hat you need for structural strength
c_rex
Quick! Into the transmogrifier!
Reply #42 on:
July 28, 2008, 03:20:58 PM »
Quote from: hypurone on July 28, 2008, 12:53:13 PM
I'd still get in trouble with my wife.
Reply #43 on:
July 28, 2008, 03:52:14 PM »
NOt if she got her own carbon fiber tits.
truckinduc
Reply #44 on:
July 28, 2008, 04:12:22 PM »
Quote from: weemonster on July 28, 2008, 02:23:34 PM
What are you talking about? I use real carbon. Id use pre preg if i could get ahold of it. its like 150$ a yard though at the cheapest. i predict my airbox will weigh an eighth of the stock one. and an airbox isnt wery structural, but ive been toying with doing a subframe
5
6
