putting my bike together...please help me out along the way..
Started by Rudemouthsky, March 16, 2015, 03:27:56 AM
Rudemouthsky
Woops, my calculation was off. I'm 1/4" taller than his Ohlins is what I meant.
That's only 5mm ay, so you wouldn't reckon it would hurt.
Rudemouthsky
It's 1/4" or about 6.5 mm.
I really like this shock otherwise I'd love an excuse to buy more stuff. Anyone have an idea how I'd determine if it will work or not with the bike in the air as it is?
 [laugh] make the beast with two backsing Imperial measurements!
Quote from: Rudemouthsky on March 18, 2015, 04:21:32 PM
You really can't tell without loading the suspension. It will all come down to how close the stock and billet hoops are in dimension. 1/4" isn't much. I have the stock Heim joints extended past recommended length as well and it's no issue as far as ride height.
Don't get paralyzed...keep moving forward. [thumbsup]
From the pic, it looks closer to 15.25" center to center.
Quote from: Rudemouthsky on March 18, 2015, 09:42:28 AM
I have almost exactly 13.25" center to center.
Thoughts?
Rudemouthsky
Quote from: Speeddog on March 18, 2015, 07:50:31 PM
Yeah that's misleading. It's 13.25. I thought about that after I posted too.
Rudemouthsky
Quote from: koko64 on March 18, 2015, 08:16:38 PM
The bike is looking great btw.
Thanks...the camera pics with the backdrop of my messy garage aren't meant to be flattering tho. I'm looking forward to taking some proper photos of a real bike soon.
Waiting on various shims and doodads from Commoto...and a single flathead M6X16 cap screw.  [roll]
Rudemouthsky
Thanks very much for everyone's input so far, it's a great confidence builder to know I have this tech section to fall back on.
Next question: I'd like to hook up the electrical, carbs and fuel plumbing today and hear the motor. I need to block off the inlet line in my gas tank as it's for an injected bike, and I don't want to jerry rig/half ass it. Does anyone know of an actual blanking piece of hardware that's made for this? otherwise the only other options I can think of are to use a vacuum cap which may not resist the fuel, or clamp a length of fuel hose to it, fold over and clamp again...which seems like a sturdy solution...but very much a "jerry rig"..
Viton is recommended for gasoline. Nitrile is a close second.
Keep in mind theinlet is at the top of the tank. You can put a small amount of fuel in to satisfy the urge to hear it and give you time to locate some caps. Use one at each end. I think you'll have better luck.
oldndumb
I am also one of the many following and admiring your build.  [clap]
Sounds like another use for the ClampTite.  :)
Rudemouthsky
Ok I couldn't wait to get it on the ground....is it me or hoooboy is this close?
