Carb hose and other sundry questions
Started by bdfinally, April 04, 2015, 09:53:24 AM
bdfinally
Yup, I couldn't wrap my head around that idea. But then he couldn't figure out why I had wanted the carbs rebuilt initially if it was running "OK"
Quote from: bdfinally on May 12, 2015, 11:54:10 AM
That's not an unreasonable question.
Why did you have them rebuilt?
bdfinally
They hadn't been cracked open in 14 years/32,000+ miles
Quote from: bdfinally on May 12, 2015, 12:19:14 PM
They needed needle jet tubes then.
You should see improved fuel mileage once you get it back on the road.
If it's been a lot of miles since a valve adjust, they always run smoother if the closers are set to the as close as possible to 0 spec, it might not be a bad idea to let them set the bike up.
bdfinally
That's what I figured, it was just time to freshen everything up and why I rebuilt the pump and replaced the fuel and vacuum lines at the same time. Everything worked "ok," but why wait for a problem to surface.
Bike only has maybe 2000 miles on it since I did the valves 2 years ago.
Quote from: bdfinally on May 12, 2015, 12:58:59 PM
Just have them synch the carbs....
or buy one of these...
http://www.amazon.com/Motion-Pro-08-0411-Syncpro-Carburetor/dp/B000K7JHWA
and do it yourself.
bdfinally
I think I'm done with air/fuel for awhile. ;)
Steering bearings are next when hot & nasty sets in.
memper
How could a shop possibly sync CV carbs while off the bike? A sync is dependent on vacuum, no?
Thats one way. Its the best way (manometer), letting you synch over a rev range. Doing it with the carbs off the bike gives you the off idle synch which on some bikes is the best you can do. I sometimes do it with carbs off the bike to get in the ball park and finish with the manometer on the bike.
bdfinally
and the saga continues! Took it back to the shop and they synched, adjusted mixture and speed. Ran fine the 2 days I rode to work. Just took it out on the highway and it's sputtering and gasping at speed. Any particular things I can look for to solve that?
You know I've been considering FCR39's for the last few years, if I'd known this was going to run over $500, I'd had probably just contacted Chris for a pair.
Problems at speed are typically fuel delivery which can be pump or venting.
It can also be an issue with the slides not lifting which can also be caused by a few things.
Nibor
I had some intermittent problems with fuel starving/flooding/something on the 750. basically when I was giving it stick, especially over $1.20, for a while, it would stutter and die. if I caught it quick and rolled off I could drop to 60 and limp for a while, otherwise i'd be on the side of the road for 10min before starting up again.
no idea what it was, but i've got some FCR39's for the rebuild  [Dolph]
bdfinally
Quote from: ducpainter on May 23, 2015, 08:26:07 AM
Well I  rebuilt the pump (http://www.ducatimonsterforum.org/index.php?topic=70457.msg1301826#msg1301826), but that was awfully straightforward, don't know where I could have gone wrong on that. Are you talking about the tank vent or off the carbs?
I was thinking tank vent.
Did you look at a plug by any chance?
bdfinally
#44
Pulled both, look like the cup of coffee with creamer in I'm having. What's aggravating is they wrote on the back of work order that they test rode it.
