January 06, 2025, 06:34:14 AM *
Pages: 1 [2]   Go Down
Author Topic: Passenger Pegs for 1100S  (Read 4575 times)
danaid
« Reply #15 on: April 24, 2015, 08:52:03 AM »
 I ordered the s&p kit. My bike has full Termignoni exhaust and I wasn't sure if the rizoma would fit, plus I don't like the way the rizoma runs across the exhaust pipe, but I guess it doesn't really matter since the kits are both removable when not being used. I was leary of removing the larger mounting pin to install a set of frame sliders, but it was fast and easy.
 One end of the pin has a nut on it, remove the nut and drive the old pin out using the new pin, a floor jack under the engine was needed when I installed sliders on my 696, but wasn't necessary when I installed the sliders on my 1100, same concept with the rear subframe pin.
« Last Edit: April 24, 2015, 07:43:46 PM by danaid » Logged
11' 1198SP  Black
09' 1100S    Red
StephenC
« Reply #16 on: April 25, 2015, 12:01:28 AM »
I've ordered the Rizoma kit, from BikeCraft.  I've started a thread in Tech (http://www.ducatimonsterforum.org/index.php?topic=70774.0) as this is becoming more of a Tech question.  Thanks to everybody, for their input.  Good luck with your install danaid.
Ducati Monster 1100S (2009)
StephenC
« Reply #17 on: May 14, 2015, 05:19:41 PM »
OK, the kit finally came through, so here's how it went.  The instal was super easy, with the engine supported on a jack.  I've written up a How To (http://www.ducatimonsterforum.org/index.php?topic=70929.0).
Here's the bike with the structural rod in place, but the hangers left off:
I think it looks pretty tidy.  The hangers then just bolt on with four bolts (two each side):
I'm very pleased.  I will probably leave them off most of the time, to keep the back looking clean, but can stick them on to take a pillion in a couple of minutes.  Thanks to everybody for their help and advice.
danaid
« Reply #18 on: May 15, 2015, 02:19:38 PM »
  Very nice!
 I received my S&P kit the other day. I have not installed the kit yet, but I'm not liking it and might sell the kit.
 Does the passenger peg arm flair out past the heal guard? I have the same rear sets, but with full Termignoni exhaust, I don't know if there would be clearance issues.
11' 1198SP  Black
09' 1100S    Red
StephenC
« Reply #19 on: May 15, 2015, 02:59:55 PM »
They do flair out a bit but if your pipes were any lower you might have a problem as they sit more below the heat guards than outside them.
Pages: 1 [2]   Go Up
