timing advanced or retarded
Started by ducatigirl100, May 22, 2015, 06:38:22 PM
ducatigirl100
#15
Quote from: koko64 on May 23, 2015, 03:45:22 PM
Cool. The full adv mark line up ok in the window?
actually my boyfriend who's a ex AMA racer check it for me  ;D....  I use to know how to use a strobe  but I didint excacly remember it ...
he tells me the at idle the strobe ligth lines up and when it's at full advance he moves to the point of almost loosig the line because it aroud 32 degres.
ROBOFLOX 77
Hi
Sounds like you're onto it. On the subject of plugs, always check the gap of so called factory set plugs, Ive had brand new ones unopened, in the card board sleeves three correct, one miles out!  More than once.
Too wide a gap can cause same symptoms as above.
Quote from: ducatigirl100 on May 23, 2015, 04:00:47 PM
With stock ignition setting, the full advance dot should come around as the revs rise and line up at full advance with the reference mark or pointer.
