September 05, 2024, 06:26:22 AM
Help FCR idle trouble
Topic: Help FCR idle trouble (Read 3784 times)
Re: Help FCR idle trouble
Reply #15 on:
July 18, 2008, 05:20:57 PM »
Check your battery cables, make sure they're all tight, if they're loose, it can whack the ignition units.
Some Dude
Reply #16 on:
July 18, 2008, 06:14:59 PM »
Quote from: Speeddog on July 18, 2008, 05:20:57 PM
Will do, could starting it on a charger also cause this?
Bike Info
99 m900s Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
knightrider
Reply #17 on:
July 18, 2008, 07:23:59 PM »
did you have the charger set to a high amperage like a setting for jump starting a car? from what i hear, and my own expierence you shouldnt hook up a motorcycle to more than maybe 10 amps at the max. if my battery is dead i will hook up my charger at the 2 amp setting for a couple mins and it will fire after that.
1994 M900
Some Dude
Reply #18 on:
July 18, 2008, 07:49:32 PM »
No it's a 10 amp charger. I have a small battery and if i need to start it more than about 5 times (with out riding it) the battery goes dead.
Bike Info
99 m900s Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
knightrider
Reply #19 on:
July 18, 2008, 07:51:00 PM »
yea i hear ya, ive got a small battery too, i cant crank it too much without needing to jump it.
1994 M900
