January 01, 2025, 08:21:42 AM
monster 620 bore increase
5
6
7
8
Topic: monster 620 bore increase (Read 24683 times)
Re: monster 620 bore increase
Reply #60 on:
July 16, 2016, 10:33:39 AM »
Quote from: DarkMonster620 on July 16, 2016, 10:26:41 AM
Well . . found a possible 800 donor engine but, I would use my 620 cases to keep engine # and not have to re-register a new engine . . . Also going for ECU . . .
would have an 800 mild hc engine under the cloack of 620 cases . . .
Enjoying the ride
Reply #61 on:
July 16, 2016, 04:10:19 PM »
Syscrush
Reply #62 on:
July 18, 2016, 01:20:16 PM »
I don't know what register means in this context, but I advise you to make sure your insurance company knows what you've done, or you're likely to invalidate your policy.
Enjoying the ride
Reply #63 on:
July 18, 2016, 01:36:25 PM »
Quote from: Syscrush on July 18, 2016, 01:20:16 PM
not where I live...not USA
Enjoying the ride
Reply #64 on:
August 04, 2016, 08:06:25 PM »
Well . . found a donor engine/ecu for internals so that I can still use my cases to keep my engine legit here . . .some work will be done to said internals . . .
updates as they happen
Reply #65 on:
August 04, 2016, 08:12:44 PM »
Cool. Looking forward to hearing how she goes.
Enjoying the ride
Reply #66 on:
August 06, 2016, 03:49:28 PM »
Quote from: koko64 on August 04, 2016, 08:12:44 PM
while I wait for engine tool to remobe engine and have mobility . . . I will study "how to" tune the ECU with different softwares and "butt-dyno" . . .
Into that subject, any if the techs in this thread could recommend a "good NOT expensivo" dyno with pros and cons . . . it would be a great help, maybe I could become "that guy" and get more business by attracting other shops and maybe purchase a tunning software or 2
Reply #67 on:
August 24, 2016, 04:39:53 AM »
Maybe a used dynojet dyno?
Enjoying the ride
Reply #68 on:
August 24, 2016, 05:27:00 AM »
I'm looking . . . remember, is just NOT the price of the equipment but, the shipping and import duties
Reply #69 on:
August 24, 2016, 05:52:11 AM »
Check with the vet on used Dyno Jet equipment. He's experienced.
Enjoying the ride
Reply #70 on:
August 24, 2016, 07:05:23 AM »
Quote from: ducpainter on August 24, 2016, 05:52:11 AM
wished I could send him my bike . . .
Reply #71 on:
October 04, 2016, 02:17:14 AM »
How's it going mate?
thorn14
Reply #72 on:
November 25, 2016, 02:23:06 PM »
Swapping the 800 in place of the 620 was the single best hp gain I got. I spent less than $1/cc for it. Took a day to swap in. And I've put almost 80k on it since.
M620
turned
M800
but then back to M620 after the M800 died at 110k, and now to Multi 1000.
POCO LOCO
Reply #73 on:
November 29, 2016, 09:57:26 PM »
What compression ratio would I attain if I used the FBF 12:1 750 pistons with 800 cylinders and 620 heads ? The reason I ask is FBF are currently out of 88mm 11:1 pistons that would give me 12:1 in a 620.
Reply #74 on:
November 30, 2016, 04:35:06 AM »
Quote from: POCO LOCO on November 29, 2016, 09:57:26 PM
I'm not capable of giving you that number, but it will likely be high enough that you'd need race gas.
If this is a track only bike that's fine, but are you going to carry 5 gallon pails of fuel?
As it is, 12:1 might be tough with pump gas.
5
6
7
8
