05 Monster S4R build
Started by Wyatterp1990, December 04, 2015, 11:20:51 PM
beethoven
Hey Wyat
7 day resurrection. Very impressive!  [clap]
Go ride!
97_M900                                                     07_Triumph_Sprint
Wyatterp1990
Thank you, I get a little obsessive when it comes to projects ha-ha. Going to be a lovely day for a ride today  [Dolph]
Wyatterp1990
So I took her out for the first ride of my ownership and she rode like a dream, however I noticed the speedometer is not working, all other parts of the gauge is working except for the speedo. I checked to see if the mileage was recording and it is not, and the needle does move when the bike is turned on, so I'm thinking that the wiring is not working somewhere, any advice or locations I should check? Thank you in advanced.
Speedo sensor is mounted to rear caliper bracket, wiring is routed along with the rear brake hose.
IIRC, it connects to the harness just a bit forward of the right rear motor mount.
You've got a wave rotor on the rear, it may not have the pins for the sensor to trigger on.
Wyatterp1990
Awesome, thank you, I'll see if I can track down the issue
Wyatterp1990
So after talking to the previous owner he said the speedo stopped working after he installed the power commander  [bang]
Anyone heard of this happening before and know of a way to fix it, other than disconnecting the power commander?
Quote from: Wyatterp1990 on December 15, 2015, 04:21:49 PM
You might want to start a new thread about this as a build thread won't gain the attention of the power commander geeks. ;D
Wyatterp1990
mtewes7
Quote from: Wyatterp1990 on December 08, 2015, 10:15:32 PM
Removed the old clutch, and replaced with new parts, I think it looks really good! Can't wait to see how the clutch feels.
I have been looking everywhere for this Clutch Cover, where did you find it??
SwiftTone
Quote from: Wyatterp1990 on December 16, 2015, 08:50:30 AM
Mtewes7,
I got it off of ebay, here is the link!
http://www.ebay.com/itm/291477044369?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Fyi, if the bike happen to fall and land on the clutch basket, it will sheer the springs right off and leave you stranded. Just keep that in mind.
Kopfjäger
Quote from: SwiftTone on December 16, 2015, 02:03:22 PM
Meh   ;)
Wyatterp1990
That's always a risk with open clutch covers, the only way I see of preventing that is by having a closed clutch cover. I guess it just comes down to whether or not the risk is worth it to have the clutch vented and having an awesome looking clutch cover.
If you fall on the left side and shear your left hand off...yer make the beast with two backsed too.
The pc shouldnt affect speedo. Check the rotor sensor spacing sensor connnecor then check with another sensor if all that fails.
