December 29, 2024, 10:37:31 AM *
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Ducati Monster Refresh (Pic heavy)  (Read 21137 times)
Yorkie
« on: January 15, 2016, 09:24:08 AM »
After owning my 1999 Ducati Monster Dark (originally a 600) from new it was about time to give it a full refresh.
It started life as a 600cc and over a period of time ended up a 900cc with lots of non-standard bits.
It has been ridden all year round and has been borrowed by a few amateur photographers ....
I was part way through stripping it down, when I bought a ratty Ducati ST2 for £450.  So I decided to put the ST2 engine in the Monster.
ST2 Engine out of its frame:
ST2 Engine stripped down:
Lightened flywheel, it went from 5kg to 1.3kg:
Monster in bits:
Yorkie
Yorkie
« Reply #1 on: January 15, 2016, 09:33:27 AM »
I kept working on reducing the weight of the ST2 Engine.  So I had the primary gears trimmed a little:
The engine mount had been damaged so a repair needed to be done:
All welded up:
The ST2 engine was soda blasted and the welding smoothed over, so you can hardly see the repair:
The crank was balanced and trimmed to suit (sorry about the crap picture):
The engine was then etch primed and lacquered, so a nice battleship grey result:
Yorkie
Yorkie
« Reply #2 on: January 15, 2016, 09:40:32 AM »
The engine was then mocked up in the Monster frame for a test fit:
Hoses and loom laid up:
To mount the radiator I had to cut the mounts off the ST2 frame and weld them on to the Monster frame:
Radiator fits just nice:
The injectors highlighted a problem when it came to fitting the air-filters and intakes, there wasn't enough clearance so a little bit of trimming would need to be done to the frame:
Yorkie
Yorkie
« Reply #3 on: January 15, 2016, 09:48:36 AM »
To give the custom alloy intakes enough room to fit, nearly all of the central beam needed to be removed:
Because the removal of the central beam would potentially weakened the structure so I decided to weld in a little bit of over engineering:
Tacked into place:
It gave a nice fit in the end:
Yorkie
Yorkie
« Reply #4 on: January 15, 2016, 09:54:13 AM »
The engine and custom spaghetti stainless steel exhaust mocked up:
I had to trim the battery box to allow the air-filter fitment:
Other trick parts were the alloy adjustable cam wheels ready for fitting to the finished engine:
Yorkie
Yorkie
« Reply #5 on: January 15, 2016, 09:57:48 AM »
I cut a little bit of weight off the clutch case, I had it roughly milled to start with:
I then went a bit further with a hand saw and some files:
It looks quite good with an alloy clutch basket:
Yorkie
Yorkie
« Reply #6 on: January 15, 2016, 10:02:59 AM »
While I waited for a powder coater and some little bits of welding to be done I took a plunge and trimmed the long standard front mud guard a bit:
This is how the Monster is at the moment:
Hopefully the powder coaters will take the bits in at the end of next week.
Yorkie
« Reply #7 on: January 15, 2016, 11:00:00 AM »
Wow. In for a penny, in for a pound! You don't muck around!
Will be watching your progress with great interest. Cheers.
Yorkie
« Reply #8 on: January 15, 2016, 11:02:11 AM »
This project is going slowly because I am doing two side by side.  I will post the other one up today as well.
Yorkie
« Reply #9 on: January 15, 2016, 11:16:30 AM »
G'day Yorkie, what's the other job?
Yorkie
« Reply #10 on: January 15, 2016, 11:22:39 AM »
Koko64,
I have just posted it up.
Yorkie
muskrat
« Reply #11 on: January 17, 2016, 11:25:38 AM »
nice job, looks awesome
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Heath
« Reply #12 on: January 17, 2016, 04:40:19 PM »
So let me get this straight. You have a pretty bad ass bike and are tearing it down to build a pretty bad ass bike?
2007 Ducati Monster S4RT
Yorkie
« Reply #13 on: January 18, 2016, 03:14:54 AM »
Correct.  I just cannot stop.
Yorkie
Heath
« Reply #14 on: January 21, 2016, 07:43:58 PM »
Yorkie
waytogo None of us can!
Pages: [1] 2 3 ... 5   Go Up
