Ducati Monster Refresh (Pic heavy)
Started by Yorkie, January 15, 2016, 09:24:08 AM
Yorkie
The welding is now done:
Powder Coat on Monday.
Yorkie
Wzed
Do you have a before-after weight for the motor?  I'm curious how many kilos you dropped - I'd guess ten or so?
Yorkie
Quote from: Wzed on January 26, 2016, 09:28:01 AM
I am hoping that it will be no more than the standard Monster 600 it started out as, even with the bigger water cooled engine.
I keep trying to trim a little off here and there.
Yorkie
Yorkie
Really slow going, whilst waiting for the powder coating and painting to be completed.  So I decided to start gathering up some blingy bits and bobs.
Picked up some bargain silicone hoses from AS3 Performance:
http://www.as3performance.co.uk/ducati-st2-1997-2003-high-performance-silicone-radiator-hoses-red/
All I need to find out now is what size alloy finishers I need:
http://www.ebay.co.uk/itm/8-AN8-17mm-RED-HOSE-END-FINISHER-Fuel-Oil-Water-Pipe-JUBILEE-CLIP-Clamp-/271083315717?hash=item3f1dd32205
More stuff to follow as it arrives.
Yorkie
Yorkie
I know it has been a while but here are the body panels:
The trimmed and de-seamed front mudguard looks okay:
I will be picking up the powder coating on Thursday.
Yorkie
Yorkie
The powder coating is home, and looks bloody good.
The modified frame:
The rear wheel and suspension hoop:
Yorkie
Yorkie
Slowly to be honest.  Work gets in the way.  I am hoping to have it together for the summer.
Yorkie
Love to see you do a hi comp, short manifold, split FCR motor with ported heads one day. Monster needs some frame struts moved to do it which I wasnt prepared to do. With hotter cams, bigger valves, porting and short manifolds on a 944 motor some have got 100 aircooled horsepower.
Pretty cool.
I reckon you're the man to do it. ;D
Yorkie
I have a 900 engine to play with that has Hi-Comp pistons already (it is in the other project) and I will be refreshing the engine once that this one is almost complete.
I will be trimming some weight off the internals and clutch casing to start with.  I will see what else I can get hold of for that one, at the right price!!
Yorkie
Heath
Do you know what brand and exact color red was used in the powder coating?
2007 Ducati Monster S4RT
Yorkie
Quote from: Heath on June 03, 2016, 12:24:08 AM
Sorry I don't, I just asked for red and this is what he did.
Yorkie
Yorkie
I know it is almost 3 months since the last post but here goes a small update.
Collected the valve, cam and clutch cases from the painters, a really nice gold:
Home made Corse clutch case (this will be my spare):
My home made extreme clutch case:
Mocked up the clutch case, I think it looks really good against the primer grey:
So this is how far I got today - almost a complete bottom end back together and sealed.  Roll on next weekend and hopefully it will be complete.
Yorkie
